copy block
copy block
copy block
hi,
I am unable to copy a block from one ACAD drawing to another can any one help me on this.
thanks in advance
namrata
cut and paste it?
wrote in message news:5007941@discussion.autodesk.com...
hi,
help me on this.
thanks in advance
namrata
yah copy and paste using dot net API
regards,
namrata
Here's an example to start with.
public void CopyBlock(string sourceFileName, string blockName)
try
using(Database sourceDatabase =
GetDatabaseFromFile(sourceFileName))
HostApplicationServices.WorkingDatabase.Insert(blockName, sourceDatabase,
false);
catch (Autodesk.AutoCAD.Runtime.Exception e)
//Application.ShowAlertDialog(e.Message);
public Database GetDatabaseFromFile(string fileName)
Database databaseFromFile = new Database(false, true);
databaseFromFile.ReadDwgFile(fileName, System.IO.FileShare.None,
false, null);
return databaseFromFile;
Bobby C. Jones
http://www.acadx.com
hi,
help me on this.
thanks in advance
namrata
this code snippet is giving an eror
it says " self refrenced"
The example I posted probably isn't what you're looking for and if you used
it to try and copy a block from a drawing into another with the same name,
then I imagine that is the error you would get 🙂
This is the overload of the Insert method that I think you are after.
currentDatabase.Insert(sourceBlockName, destinationBlockName,
sourceDatabase, true);
However, this is creating two btr's. The one with the name provided as the
sourceBlockName parameter is good, but the one provided as the
destinationBlockName is empty and can be purged. I did a quick search on
the ADN site and this was reported a while back. Like in the R2004
timeframe.
Bobby C. Jones
wrote in message news:5011912@discussion.autodesk.com...
