Copy block from one layout to all other layouts same coordinates
David_Prontnicki
Message 1 of 8
David_Prontnicki
I am trying to copy a block reference to each paperspace layout tab to the same coordinates. The program currently inserts the block at the user's selected coordinates. I get the block objectId and the user selected coordinates and pass them to the sub below. I have tried may things but cant seem to get it to work. Any help would be greatly appreciated.
    Private Sub CopyToAllLayouts(acBlockReferenceObjectId As ObjectId, insertionPoint As Point3d)
        Dim acCurrentDatabase As Database = Active.Database
        Dim acDocumentEditor As Editor = Active.Editor
        Using acDocumentLock As DocumentLock = Active.Document.LockDocument()
            Using acTranaction As Transaction = Active.Database.TransactionManager.StartTransaction()
                Dim acLayoutDatabaseDictionary As DBDictionary = TryCast(acTranaction.GetObject(acCurrentDatabase.LayoutDictionaryId, OpenMode.ForRead), DBDictionary)
                For Each acLayoutDatabaseDictionaryEntry As DBDictionaryEntry In acLayoutDatabaseDictionary
                    Dim acLayout As Layout = CType(acLayoutDatabaseDictionaryEntry.Value.GetObject(OpenMode.ForRead), Layout)
                    Dim acLayoutName As String = acLayout.LayoutName
                    Dim acLayoutObjectId As ObjectId = acLayoutDatabaseDictionary.GetAt(acLayoutName)
                    Dim acBlockTableRecord = CType(acTranaction.GetObject(acLayout.BlockTableRecordId, OpenMode.ForRead), BlockTableRecord)
                    Dim acBlockReference As BlockReference = New BlockReference(insertionPoint, acBlockReferenceObjectId)
                    'Dim acBlockTable = DirectCast(acTranaction.GetObject(acCurrentDatabase.BlockTableId, OpenMode.ForRead), BlockTable)
                    'Dim acBlockReference = New BlockReference(insertionPoint, acBlockReferenceObjectId)
                    'Dim acBlockTableRecord = DirectCast(acTranaction.GetObject(acCurrentDatabase.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                    'acBlockReference.TransformBy(acDocumentEditor.CurrentUserCoordinateSystem)
                    acBlockTableRecord.UpgradeOpen()
                    acBlockTableRecord.AppendEntity(acBlockReference)
                    acTranaction.AddNewlyCreatedDBObject(acBlockReference, True)
                Next
                acTranaction.Commit()
            End Using
        End Using
    End Sub
Replies (7)
Message 2 of 8
_gile
This should work.
        private static void CopyToAllLayouts(ObjectId blockTableRecordId, Point3d position)
            var db = HostApplicationServices.WorkingDatabase;
            using (var tr = db.TransactionManager.StartTransaction())
                var layouts = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
                foreach (DBDictionaryEntry entry in layouts)
                    if (entry.Key != "Model")
                        var layout = (Layout)tr.GetObject(entry.Value, OpenMode.ForRead);
                        var btr = (BlockTableRecord)tr.GetObject(layout.BlockTableRecordId, OpenMode.ForWrite);
                        var br = new BlockReference(position, blockTableRecordId);
                        btr.AppendEntity(br);
                        tr.AddNewlyCreatedDBObject(br, true);
                tr.Commit();
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 8
David_Prontnicki
@_gile
Thank you for the speedy reply. One small problem. It is copying the block to the right location but the attributes are now empty. The block contains 5 attribute values that get applied on initial insertion. That works perfect. during the copy process the attributes are now blank. Any ideas why that may be?
Message 4 of 8
_gile
With .NET, you have to explicitly create the attribute references using the attribute definitions as templates. See this topic.
                // insert the block reference
                var owner = (BlockTableRecord)tr.GetObject(layout.BlockTableRecordId, OpenMode.ForWrite);
                owner.AppendEntity(br);
                // add attribute references
                var btr = (BlockTableRecord)tr.GetObject(blockTableRecordId, OpenMode.ForRead);
                foreach (ObjectId id in btr)
                    if (id.ObjectClass == RXObject.GetClass(typeof(AttributeDefinition)))
                        var attDef = (AttributeDefinition)tr.GetObject(id, OpenMode.ForRead);
                        if (!attDef.Constant)
                            var attRef = new AttributeReference();
                            attRef.SetAttributeFromBlock(attDef, br.BlockTransform);
                            br.AttributeCollection.AppendAttribute(attRef);
                            tr.AddNewlyCreatedDBObject(attRef, true);
        tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Message 5 of 8
lena.talkhina
Hello @David_Prontnicki !
Great to see you here on .NET forum.
Don't forget to accept a solution when you receive the answer which works for you.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 6 of 8
David_Prontnicki
@_gile
Thank you very much. Works perfect. I appreciate all the help, and apologize for not mentioning the attributes in the OP.
Message 7 of 8
David_Prontnicki
@_gile
One last question....
One of the attributes may or may not contain a width factor that is set on insert.
How can I assign the same width factor to each "copied" block's attribute. I have tried many things over the weekend and cant seem to figure it out. I have the tag name for the attribute and the width but cant seem to figure out how to apply it to that attribute during the copy process.
Message 8 of 8
David_Prontnicki
@_gile
Never mind. Of course I figure it out after I post. LOL sometimes typing out the question gets you the answer.
Private Sub CopyBlockToAllLayouts(acInsertedBlockTableRecordObjectId As ObjectId, insertionPoint As Point3d)
        Dim professionalAttributeObjectId As ObjectId
            Using acTranaction As Transaction = acCurrentDatabase.TransactionManager.StartTransaction()
                Dim acLayoutDatabaseDictionary = CType(acTranaction.GetObject(acCurrentDatabase.LayoutDictionaryId, OpenMode.ForRead), DBDictionary)
                    If acLayoutDatabaseDictionaryEntry.Key <> "Model" Then
                        Dim acLayout = CType(acTranaction.GetObject(acLayoutDatabaseDictionaryEntry.Value, OpenMode.ForRead), Layout)
                        Dim acBlockTableRecordOwner = CType(acTranaction.GetObject(acLayout.BlockTableRecordId, OpenMode.ForWrite), BlockTableRecord)
                        Dim acBlockReference = New BlockReference(insertionPoint, acInsertedBlockTableRecordObjectId)
                        acBlockTableRecordOwner.AppendEntity(acBlockReference)
                        Dim acBlockTableRecord = CType(acTranaction.GetObject(acInsertedBlockTableRecordObjectId, OpenMode.ForRead), BlockTableRecord)
                        For Each acAtributeDefinitionObjectId As ObjectId In acBlockTableRecord
                            If acAtributeDefinitionObjectId.ObjectClass = RXObject.GetClass(GetType(AttributeDefinition)) Then
                                Dim acAttributeDefinition = CType(acTranaction.GetObject(acAtributeDefinitionObjectId, OpenMode.ForRead), AttributeDefinition)
                                If Not acAttributeDefinition.Constant Then
                                    Dim acAttributeReference As New AttributeReference()
                                    acAttributeReference.SetAttributeFromBlock(acAttributeDefinition, acBlockReference.BlockTransform)
'Added this line
                                    acAttributeReference.TextString = acAttributeDefinition.TextString
                                    acBlockReference.AttributeCollection.AppendAttribute(acAttributeReference)
                                    acTranaction.AddNewlyCreatedDBObject(acAttributeReference, True)
'added select case and ran my SetNameAttributeWidth sub
                                    Select Case acAttributeDefinition.Tag
                                        Case "PROFESSIONAL"
                                            professionalAttributeObjectId = acAttributeReference.ObjectId
                                            SetNameAttributeWidth(professionalAttributeObjectId, 2.7)
                                    End Select
                                End If
                            End If
                        Next
                    End If
                Next
            End Using
        End Using
    End Sub
