copy a layer from a drawing to another
Message 1 of 9
Hello, Guys.
My name is Bruno. I'm trying to copy a layer from a drawing to another, using dot net, but I'm not getting to do it. I already did it with VBA (using copybjects), and with ARX (using deepclone), but when I do using dot net, appears a error message when I open the layer properties manager: "no active transactions".
Here is the code I'm using:
Private Sub copyLayerFromAnotherDrawing(ByVal layerStr As String, ByVal fromFileStr As String)
Dim LT, myLt As LayerTable
Dim tm, myTm As DBTransMan
Dim ta, myTa As Transaction
Dim dbMe, dbFrom As New Database
Dim lyr, copy As LayerTableRecord
Dim itens As SymbolTableEnumerator
Dim id As ObjectId
Dim idMap As New IdMapping()
dbMe = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database
dbFrom.ReadDwgFile(fromFileStr, IO.FileShare.Read, True, "")
tm = dbFrom.TransactionManager
ta = tm.StartTransaction
LT = ta.GetObject(dbFrom.LayerTableId, OpenMode.ForRead, False)
myTm = dbMe.TransactionManager
myTa = myTm.StartTransaction
myLt = myTa.GetObject(dbMe.LayerTableId, OpenMode.ForWrite, False)
itens = LT.GetEnumerator
Do While itens.MoveNext
id = itens.Current
lyr = tm.GetObject(id, OpenMode.ForRead)
If lyr.Name.CompareTo(layerStr) = 0 Then
copy = lyr.DeepClone(myLt, idMap, False)
myLt.Add(copy)
myTa.AddNewlyCreatedDBObject(copy, True)
Exit Do
End If
Loop
myTa.Commit()
ta.Commit()
End Sub
Thanx for de help.
Replies (8)
Message 2 of 9
Hi Bruno
Try this instead
Public Sub CopyLayerFrom(ByVal lname As String, ByVal fname As String)
Try
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim thisDb As Database = HostApplicationServices.WorkingDatabase
Using docLock As DocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument
Try
Using db As Database = New Database(False, False)
Try
db.ReadDwgFile(fname, System.IO.FileShare.Read, True, Nothing)
Using tr As Transaction = db.TransactionManager.StartTransaction
Try
Dim lt = tr.GetObject(db.LayerTableId, OpenMode.ForRead, False)
Dim ltr As LayerTableRecord = tr.GetObject(lt(lname), OpenMode.ForRead)
Using thisTr As Transaction = thisDb.TransactionManager.StartTransaction
Dim thisLt As LayerTable = thisTr.GetObject(thisDb.LayerTableId, OpenMode.ForWrite)
Dim map As New IdMapping()
Dim objIDs As ObjectIdCollection = New ObjectIdCollection
objIDs.Add(ltr.ObjectId)
thisDb.WblockCloneObjects(objIDs, thisLt.ObjectId, map, DuplicateRecordCloning.Replace, False) 'no defer
thisTr.Commit()
End Using
tr.Commit()
Finally
CType(tr, IDisposable).Dispose()
End Try
End Using
Finally
CType(db, IDisposable).Dispose()
End Try
End Using
Finally
CType(docLock, IDisposable).Dispose()
End Try
End Using
Catch ex As Autodesk.AutoCAD.Runtime.Exception
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
ed.WriteMessage(ControlChars.CrLf & "Error {0} Copy layer from other document" & ControlChars.CrLf, ex)
ed.WriteMessage(ex.StackTrace)
End Try
End Sub
~'J'~
Message 3 of 9
Fatty - At the risk of discouraging you from posting code, I am going to say this anways, because I think others that come here to get help and learn to code using the .NET API, are entitled to know it.
I mentioned this to you in the past, but you chosen to ignore it for whatever reason, and as a result, you are posting code that does not serve as a good example for anyone.
So mainly for the benefit of others, here it goes yet once again:
You do not call Dispose() on objects that are under control of 'Using', because that is what 'Using' is for, to begin with. 'Using' automatically calls Dispose() for you.
And so, this:
Using obj As MyDisposable = New MyDisposable()
obj.DoSomething() ' use 'obj' here
End Using
is exactly the same as this:
Dim obj As MyDisposable = New MyDisposable()
Try
Finally
obj.Dispose()
End Try
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:[email protected]...
Hi Bruno
Try this instead
Try
Try
Try
Try
thisTr.Commit()
End Using
tr.Commit()
Finally
End Try
End Using
Finally
End Try
End Using
Finally
End Try
End Using
End Try
End Sub
~'J'~
Message 4 of 9
Sorry, Tony
You are right completely, as always
I have been in a hurry when I have writing
this code
Thanks again for the lesson about 'Using'
With deep regards,
~'J'~
Message 5 of 9
Here is edited version, I hope it will correct
Try
Dim ed As Editor = doc.Editor
If lt.Has(lname) Then
If Not ltr.IsErased Then
thisTr.Commit()
End Using
tr.Commit()
End If
End If
End Using
End Using
End Using
End Try
End Sub
~'J'~
Message 6 of 9
Hello, Fatty. Thanx for the answer.
I tryied this before, and got the following error: "filler error", when I used WblockCloneObjects method.
Message 7 of 9
Hi Bruno,
I don't know why this not working for you
This worked for me 10 times from 10 with several
drawings and layers
A2008/VS2005
~'J'~
Message 8 of 9
I Tryied again and worked this time. Your code isn't identical to the code a wrote before. I don't know what I was doing wrong. I've just copyied your code and worked.
Thanx, Fatty. I was almost givin up.
Bruno Neves Pires Silva
Message 9 of 9
Hi Bruno
Glad if this worked now
Happy computing 🙂
~'J'~
