Converting colors
Converting colors
Message 1 of 16
Converting colors
How do I convert an AutoCad color to a system.drawing.color if the AutoCad. color is by Index
switch (autoCadLayer.Color.ColorMethod)
case Autodesk.AutoCAD.Colors.ColorMethod.ByColor:
System.Drawing.Color color = autoCadLayer.Color.ColorValue;
break;
case Autodesk.AutoCAD.Colors.ColorMethod.ByAci:
System.Drawing.Color color = System.Drawing.Color.FromArgb(?, ?, ?);
break;
Replies (15)
Message 2 of 16
Perhaps try something like :
PromptSelectionOptions selectionOptions = new PromptSelectionOptions();
PromptEntityResult entityRes = ed.GetEntity("\nPick something");
//Do nothing if selection is unsuccessful
if (entityRes.Status != PromptStatus.OK)
return;
Entity ent = (Entity)tr.GetObject(entityRes.ObjectId, OpenMode.ForWrite);
if (ent.Color.IsByAci == false)
return;
System.Drawing.Color winColor = System.Drawing.Color.FromArgb(
ent.Color.ColorValue.A,
ent.Color.ColorValue.R,
ent.Color.ColorValue.G,
ent.Color.ColorValue.B
ed.WriteMessage("\n "
+ winColor.Name.ToString()
+ winColor.ToString()
/// kwb
wrote in message news:5571705@discussion.autodesk.com...
color is by Index
break;
break;
Message 3 of 16
Kerry
I tried this before I posted the question.
The problem is that if the color mode is by index then the ARGB slots do not contain Red Green & Blue values. The A slot appears to be 255 and the R slot holds the index number and G & B are zero
Dave
Message 4 of 16
Dave,
I'd have to see your code, but ..
It looks like you're working with a LayerTableRecord
so, by my understanding,
so you should be able to do what you need from the ltr.Color.ColorValue.R
... etc, fed to the
System.Drawing.Color.FromArgb( A, R,G, B) as I've shown.
/// kwb
wrote in message news:5573590@discussion.autodesk.com...
Kerry
Dave
Message 5 of 16
Kerry
Tks for reply. Here is the code. Its a common call when reading the layer table and the entities.
If I have a layer with a colour that is ByAci then in the ColorValue object I have the following
ColorValue = "{Name=ff050000, ARGB=(255, 5, 0, 0)}"
Five being the Acad index for Blue
If however I have a layer where the colour is ByValue I get the following, which is good
ColorValue = "{Name=ff2109f6, ARGB=(255, 33, 9, 246)}"
When I read the entities I use the same method
If the color is by layer I don't need to look at the entities color (it is empty anyway)
ColorValue = "{Name=ff000000, ARGB=(255, 0, 0, 0)}"
but if the color is not by layer I get exactky the same behaviour as above
Code snippet below.....
NB I'm on leave next week, so if you reply I am not ignoring you !
Many thanks
Dave
Message 6 of 16
Or just use EntityColor.LookUpRgb()
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"Kerry Brown" wrote in message news:5574757@discussion.autodesk.com...
Dave,
... etc, fed to the
/// kwb
Kerry
Dave
Message 7 of 16
Tony
Tks for joining in
What do you mean by EntityColor.LookUpRgb() ?
There is no LookUpRgb method or property on the AutoCAD.Colors.Color object.
Can you be more specific please ?
Dave
Message 8 of 16
Tony
Sorry - mis understood - I see there is a static method - just tryimng it now
tks
dave
Message 9 of 16
Tony
Okay - I now have this
int i = Autodesk.AutoCAD.Colors.EntityColor.LookUpRgb(acadColor.ColorValue.R);
Which returns an integer. How do I get that into RGB (in .NET)?
Tks
Dave
Message 10 of 16
For your LTR, just for the fun of it, how about :-
System.Drawing.Color argb = System.Drawing.Color.FromArgb(
AcColors.EntityColor.LookUpRgb(
System.Convert.ToByte(
ltr.Color.ColorIndex)));
/// kwb
wrote in message news:5575062@discussion.autodesk.com...
Tony
int i =
Tks
Dave
Message 11 of 16
Kerry - What's 'AcColors' ?
"Kerry Brown" wrote in message news:5575042@discussion.autodesk.com...
/// kwb
Tony
int i =
Tks
Dave
Message 12 of 16
Reading up on the Color class (the .NET one,
not the Autodesk one) should reveal how to
do it.
Tony
Tks
Dave
Message 13 of 16
On second thought, I think this is all he needs:
Autodesk.AutoCAD.Colors.Color entColor = //
System.Drawing.Color color = entColor.ColorValue;
/// kwb
Tony
int i =
Tks
Dave
Message 14 of 16
Tony,
Just a lame alias 🙂
using AcColors = Autodesk.AutoCAD.Colors;
"Tony Tanzillo" wrote in message
news:5575110@discussion.autodesk.com...
/// kwb
Tony
int i =
Tks
Dave
Message 15 of 16
Yep, Works for me 🙂
ltr = (LayerTableRecord)tm.GetObject(ltrId,
OpenMode.ForRead);
ltr.Color.ColorValue;
/// kwb
href="http://www.caddzone.com">
size=2>http://www.caddzone.com
size=2>AcadXTabs: MDI Document Tabs for AutoCAD 2008
through 2008
size=2>http://www.acadxtabs.com
"Kerry
Brown" <
size=2>kwb@home
> wrote in message
size=2>news:5575042@discussion.autodesk.com
size=2>...
kwb
<Thiss> wrote in message
href="news:5575062@discussion.autodesk.com">
size=2>news:5575062@discussion.autodesk.com
size=2>...
Tony
int i =
Which
.NET)?
Tks
Dave
Message 16 of 16
Guys
All sorted tks - didn;t spot I could just pass the integer returned by the LookUpRgb into the Syste.Color.FromArgb method
Tks for help
Dave
