Convert .dwg to .bmp in AutoCAD 2013
chockalingam
chockalingam
  I want to convert the .dwg file to .bmp in AutoCAD 2013 using interop services in API
I have a code to perform this in AutoCAD 2012 but that is not working fine in AutoCAD 2013. Can anyone help me in this regarding.
This is what i tried
AcadSelectionSet oSS = null;
short[] ftype = new short[1];
ftype[0] = 410;
object[] fdata = new object[1];
fdata[0] = "Model";
acadapp.ZoomExtents();
oSS = _acadapp.ActiveDocument.SelectionSets.Add("MySet");
oSS.Select(AcSelect.acSelectionSetAll, null, null, ftype, fdata);
acadapp.ActiveDocument.Export(OutputFileName, "BMP", oSS);
Alfred.NESWADBA
use the plot-functionality, that gives you more options (espcially the resolution) for the output.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
chockalingam
Can you guide me how to do that.... Since i am not much familiar with that
Alfred.NESWADBA
create a new plotter (with the new plotter-wzard) that creates raster-files (>>>details<<<)
Then search for source-code controlling plotting, e.g. >>>click<<<.
- alfred -
Alfred NESWADBA
ow
Or you can send the BMPOUT command to the commandline.
chockalingam
Hi all,
Finally Found Solution, the code i used is follows
ftype[0] = 410;
fdata[0] = "Model";
_acadapp.ZoomExtents();
_acadapp.ActiveDocument.Export(OutputFileName, "BMP", oSS);
KillAcadDocuments(_acadapp);
just send the selection set as null, this is Exporting the BMP.
Thanks all for helping me...
