Control in WPF (Modeless) for binding the properties of an entity, is it possible?
kelcyo
Message 1 of 8
kelcyo
How can I use a control in WPF (Modeless) to control the properties of an entity in the drawing? As an example, a slider to control the length of a line...
Does anyone have a sample or suggestion?
Replies (7)
Message 2 of 8
Norman_Yuan
@kelcyo , the reason people hesitate to respond to your question is the topic is rather complicated. While the question you asked in the tile is really simple to answer: yes, it is possible/doable. But it needs quite some work to just make a very simple sample project to show, if one wants to it right: using MVVM pattern to take advantage of WPF binding, and showing modeless UI in AutoCAD properly; organizing data per document because of the UI being modeless...
Anyway, I was able to squeeze a bit of time creating a quick sample project to show how it can be done. Because of, as I said, WPF binding and modeless UI, the project has too much code that would not be suitable to post here. So, I now just post a video clip here to show how it works. I will post whole project in my blog later, when I can find a bit of time, stay tuned.
Norman Yuan
Drive CAD With Code
Message 3 of 8
kelcyo
Exactly what I mean. Waiting to see your code...thanks for the effort to help, I appreciate it...
Message 4 of 8
Norman_Yuan
Message 5 of 8
Norman_Yuan
Well, after 2 days, I updated the project and made it another post in my blog. Read it here:
https://drive-cad-with-code.blogspot.com/2022/09/update-entities-via-data-binding-of_25.html
Norman Yuan
Drive CAD With Code
Message 6 of 8
Gepaha
Norman, thank you very much for the example.
I've taken a look around and seen that it's been using Database.FingerprintGuid.
In my view Database.FingerprintGuid is not a unique identifier. Create a Database and save it under different names, they will have the same FingerprintGuid. With saveas you will get multiple drawings with the same guid.
Message 7 of 8
Norman_Yuan
@Gepaha , thank you to point it out. I was meant to use a unique key to segregate data among opened drawings in a session. So, yes, if the FingerprintGuid could be the same from different drawings because of them being copied from the same original drawing, then the code would not work correctly. This was my oversight because of wanting to make code more concise. I should have use Document, or Document.UnmanagedObject, as I mentioned in the article, as the dictionary key.
A different topic: it is interesting that Database.FigureprintGuid could remain the same if a copy of the drawing is created and named differently. Just imagine: all drawings from an office could have the same FingerripntGuid, if the drawings are from the same template file? Or, all drawings exist in the would could have the same Data base.FingerprintGuid, if they all created based on "acad.dwt". So, what the purpose to have this FingerprintGuid? Interesting, eh?
Norman Yuan
Drive CAD With Code
Message 8 of 8
Norman_Yuan
Thanks for @Gepaha pointing out a bug in my code (by using Database.FinerprintGuid as dictionary's key), I updated the code in my article and the source code for downloading.
Norman Yuan
Drive CAD With Code
