Connection
Connection
Amremad
Connection
Amremad
How Can i connect my Function in vb.net with autocad command (in drawing)
thx
arcticad
Amremad
Mr. arcticad
thank you for helping me
but i have other questions
- i will compile my vb.net project to exe file or what?? and where can i put it to run ??
<CommandMethod("CheckForPickfirstSelection", CommandFlags.UsePickSet)> _
Public Sub CheckForPickfirstSelection()
End Sub
 in this code where the command letters where can i write in the autocad command
i think i have confilict with understaning this way
Alexander.Rivilis
Ok! Let start reading from start point:  http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer%27s%20Guide/files/WS1a9193826455f5f...
Create new project
Load an Assembly to AutoCAD
Facebook | Twitter | LinkedIn
Expert Elite Member
arcticad
You will compile your program into a class library. dll file.
You can use the netload command to load the file. or use the registry to automatically load them.
<CommandMethod("Command_here")>
http://www.autodesk.com/developautocad
or
purchase VB.NET For AutoCAD 2010
http://www.vbcad.com/
If you want to know how to get started.
(defun botsbuildbots() (botsbuildbots))
