- Mute
- Permalink
- Report
I want to connect .NET with Autocad Electrical . i am using ,
AutoCAD Electrical 2025.0.2 , Product Version : 22.0.81.0 , Built on: V.154.0.0 AutoCAD 2025.1.1
Visual Studio Community 2022 - 17.12.3
my system is x64 bit
I am creating a console application in .NET 8.0 Runtime with C# language , Added dll accoremgd , acdbmgd, acmgd, Autodesk.AutoCAD.Interop . Also in .NET in Solution Explorer , in project references , i have made "Copy Local" property as False.
using System;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Runtime;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.ApplicationServices;
namespace AutoCADElecDemo
class Program
static void Main(string[] args)
AcadApplication acadApp = null;
const string progId = "AutoCAD.Application.25"; // Adjust for your AutoCAD version
try
// Get a running instance of AutoCAD
acadApp = GetActiveAutoCAD(progId);
catch (System.Exception ex)
Console.WriteLine($"Error initializing AutoCAD: {ex.Message}");
return;
try
// Ensure AutoCAD is visible
acadApp.Visible = true;
Console.WriteLine("AutoCAD is now running.");
// Register for the BeginQuit event
Application.BeginQuit += OnBeginQuit;
// Keep the application running to monitor AutoCAD's state
Console.WriteLine("Press Enter to exit...");
Console.ReadLine();
Console.WriteLine($"An error occurred: {ex.Message}");
finally
// Unregister the event handler before exiting
Application.BeginQuit -= OnBeginQuit;
static AcadApplication GetActiveAutoCAD(string progId)
try
var comObject = Marshal.GetActiveObject(progId);
Console.WriteLine($"Connected to AutoCAD: {progId}");
return (AcadApplication)comObject;
Console.WriteLine($"Error accessing AutoCAD: {ex.Message}");
throw;
static void OnBeginQuit(object sender, EventArgs e)
Console.WriteLine("AutoCAD is being closed.");
For above code, my application comes in break mode "Your app has entered a break state, but no code is currently executing that is supported by the selected debug engine (e.g. only native runtime code is executing)."
and i am getting below error :
System.IO.FileNotFoundException: 'Could not load file or assembly 'accoremgd, Version=25.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.'
dll path is also correct.
i also tried same code with .NET Framework 4.7.2 and 4.8 targeting pack , but getting same error.
How to load accoremgd.dll properly so that this application can use autocad accoremgd functions properly.
