Connection Between AutoCAD with VB.NET & how to make GUI for passing values
Message 1 of 17
            my question is how to connect vb.net with AutoCAD 2016 through .NET GUI and passing the parameters or commands to AutoCAD through VB.NET GUI. Actually I run some code to create the Instance of AutoCAD but it gives error. i have send this error as attachment. Please give the solution ASAP.
Thanx
Mohit
Replies (16)
Message 2 of 17
_gile
In the picture you provide, there's not any VB.net, it's C# language using COM interop.
So, I'm afraid it's impossible to quickly give you a solution as it looks like you're missing some basics.
Is there any reason you use COM Interop instead of the .NET API (e.g. standalone application)?
Did you reference the COM libraries corresponding to the AutoCAD version (2016) ?
Was there an instance of AutoCAD running when you clicked the button?
Gilles Chanteau
GileCAD
GitHub
Message 3 of 17
Thanx Gile,
                 Actually I send my problem fastley. Ya this is C# language. I add two refrence file that is AutoCAD and AXDBLib.
"AcadApp = (AcadApplication)Marshal.GetActiveObject("AutoCAD.Application");" on this line there is a exception.. Have you understood my problem. I can check in the task manager there is no other instance is open.
Thanx
Mohit
Message 4 of 17
Alexander.Rivilis
@Anonymous
My recommendations:
1. Download and install ObjectARX SDK appropriate version: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=785550
2. Add reference to Autodesk.AutoCAD.Interop.dll and Autodesk.AutoCAD.Interop.Common.dll from ObjectARX SDK \inc-Win32 or \inc-x64 directory dependent on bitness (32 or 64) of your application. Also set Copy Local to false for those dll's.
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 5 of 17
_gile
Marshal.GetActiveObject() method throw an exception if there's none running process of the application.
Typically, we try to get a running process, and try to start a new one if it failed.
try // try to get an already running AutoCAD process
catch
    try // try to start a new AutoCAD process
	AcadApp = System.Activator.CreateInstance(System.Type.GetTypeFromProgID("AutoCAD.Application"));
catch
MessageBox.Show("Unable to start AutoCAD.");
return;
 Anyway, you didn't reply to my questions...
Gilles Chanteau
GileCAD
GitHub
Message 6 of 17
I have added your code but there is error on the below line
SystemArgumentException
Thanx
Mohit
Message 7 of 17
Dear Alexander,
                        Thanx for your reply, i am download ObjectARX SDK and add both dlls in the program. and set Copyto local in false. But it will give same error.
Thanx
Mohit
Message 8 of 17
Dear Gile,
              I have run this code and getting some exception.please see the attachment.
AcadApp = DirectCast(Marshal.GetActiveObject("AutoCAD.Application"), Autodesk.AutoCAD.Interop.AcadApplication)
Dim blockObj As Autodesk.AutoCAD.Interop.Common.AcadBlock
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 0.0# : insertionPnt(1) = 0.0# : insertionPnt(2) = 0.0#
' Insert the block
Dim blockRefObj As Autodesk.AutoCAD.Interop.Common.AcadBlockReference
insertionPnt(0) = 2.0# : insertionPnt(1) = 2.0# : insertionPnt(2) = 0
blockRefObj = AcadApp.ActiveDocument.ModelSpace.b(insertionPnt, "D:\Pjojects\Dol Power circuit Programming\CircuitModel\ACB.dxf", 1.0#, 1.0#, 1.0#, 0)
thanx
Mohit
Message 9 of 17
_gile
MDUTTA a écrit :
' Insert the block
As far as I know (but I'm not very cumfortable with VB), the ModelSpace object do not have a 'b' method.
To insert a block reference, you have to use the InsertBlock method.
blockRefObj = AcadApp.ActiveDocument.ModelSpace.InsertBlock(insertionPnt, "D:\Pjojects\Dol Power circuit Programming\CircuitModel\ACB.dxf", 1.0#, 1.0#, 1.0#, 0)
I find it odd that Visual Studio did not report this error at edition time (i.e. before compiling), it may be a special feature of VB ...
As I (and some others) recommend to those who start learning AutoCAD .NET customization : learn C# instead of VB and avoid, as much as possible, using COM.
Gilles Chanteau
GileCAD
GitHub
Message 10 of 17
yes but this gives exception. what can i do
Message 11 of 17
Then please tell the C# code for reinserting the block.
Thanx
Mohit
Message 12 of 17
_gile
It seems to me you cannot use the InsertBlock method wit a dxf file, it have to be a dwg file.
As you're using COM, maybe you can try with SendCommand and the native INSERT command but it should be asynchronous.
Gilles Chanteau
GileCAD
GitHub
Message 13 of 17
please see the attachment i am using dxf or dwg file both gives exception
Message 14 of 17
_gile
What if you try to "manually" insert this dwg in a drawing using the INSERT command and Browse option?
Don't you have the same "Self Reference" error?
Isn't your "ACB.dwg" file containing a block named "ACB"?
Gilles Chanteau
GileCAD
GitHub
Message 15 of 17
Manually i use INSERT command and it is sucessfully inserted but through vb program it will give the self reference error.
Yes the block name is ACB
Thanx
Mohit
Message 16 of 17
_gile
Sorry,
I do not understand, as you're using VB with COM Interop, which is closed to VBA, perhaps you'd have more chance in the Visual Basic Customization forum.
Gilles Chanteau
GileCAD
GitHub
Message 17 of 17
Juergen_Becker
Hi Folks,
what I don't understand is:
Why you are using AutoCAD as a COM-Object?
Is it necessary to develop a program as a Windows program?
Why you don't develop this prorgam within the AutoCAD enviroment?
Regards Jürgen
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
