Community Toolkit for MVVM broken in .Net 8.0
Clint_Svensrud
Clint_Svensrud
Previously I have developed in .NET Framework 4.8 using the Community Toolkit for MVVM from GITHUB. After some tweaking change C# language to 10, all worked well.
In .NET 8.0 I start out debugging with a simple editor writeline. It works and I hit the break point. As soon as I declare a new class which derives from ObservableObject from the toolkit is written in the project. This breaks at NETLOAD and bypasses the debugger giving no error warnings.
I assuming this has issues due to Roselyn source code generator.
Any help with this would be appreciated.
Thanks Clint
ricaun
Are you sure is related to Community Toolkit?
It is more likely your net8 configuration is not right.
What error warnings are you receiving?
The CommunityToolkit.Mvvm.dll has been created in your output project?
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
It shouldn't be a problem with the mvvm toolkit. I'm sure this package can be used normally, whether it's net48 or net8
Clint_Svensrud
I was able to get it work with Community Toolkit by add the following to Visual Studio project file.
<CopyLocalLockFileAssemblies>true</CopyLocalLockFileAssemblies>
  <RuntimeIdentifier>win-x64</RuntimeIdentifier>
