Close/Disable resolution startup popup
哀家爆
哀家爆
AutoCAD returns an error message on start up: "AutoCAD Error Aborting: "AutoCAD requires 1024 x 768 resolution or higher to run."
I have some codes to start up an AutoCAD instance in other app:
AcadApplication acAppComObj;
const string strProgId = "AutoCAD.Application.23.1";
// Get a running instance of AutoCAD
try
    acAppComObj = (AcadApplication)Marshal.GetActiveObject(strProgId);
catch // An error occurs if no instance is running
    try
        // Create a new instance of AutoCAD
        acAppComObj = (AcadApplication)Activator.CreateInstance(Type.GetTypeFromProgID(strProgId), true);
    catch
        // If an instance of AutoCAD is not created then message and exit
        return;
Is there some api to close or disable this popup dialog while I am starting up a cad instance?
哀家爆
By the way, because of the development environment, I can't set the resolution of the computer.
