Class Module
Class Module
parikhnidi
Class Module
parikhnidi
How do I create a class module in .NET? I have started migrating from VBA to .NET and ObjectARX (the later one is bit difficult).
May be I can convert the class module I created in VBA here https://forums.autodesk.com/t5/vba/drawing-a-part-with-vba/m-p/9187173/highlight/true#M103374 to .NET version.
What I want is to develop a compiled library of various components as a class module. And later on I would like to use this library over and over again in my various application.
In archaic VBA world, it was vary easy like adding a class module and then keep them referring. I am sure that it is possible with .NET application, but not sure, how to implement them. I need to define properties similar to Let / Get / Set and methods to execute the codes.
Any pointers in this regards?
Nimish
jabowabo
You can create a Class Library in Visual Studio and add the compiled .dll as a reference into any other projects you want to use it in.
parikhnidi
Just curious. How do I define properties and methods in .NET frameworks. I am radically transforming myself from VB / VBA to .NET (I regret for not doing so for early).
Is there any sample example spoecifically dealing with class modules in documentation?
Nimish
jabowabo
Norman_Yuan
A point to note on @jabowabo provided link: it is about .NET Core (now .NET 5). While the way of creating a class in code is the same (in C#), for AutoCAD .NET API development, you use .NET Framework, not .NET Core/Standard.
Also, based on the question you asked here and in ObjectARX forum, I suggest you need to spend quite some time to get started with basic .NET framework (a few weeks/months, depending on how fask you can learn) before tackling AutoCAD .NET API development. While you can use any .NET language (VB.NET, C#, F#, Iron Python.NET), yu should choose C#, instead of VB.NET, which you might be thinking it would be more natural to transit from VBA to VB.NET. I'd say, ObjectARX C++, as you asked in the other forum, sounds definitely not for you.
Norman Yuan
Drive CAD With Code
