Check if user has done something after opening a drawing.
SRSDS
Advisor Advisor
SRSDS
I would like a to know if the user has done something has occurred after a drawing has been opened.
I can't figure out a location to store a boolean variable that:
Does not modify the document's database. If the database is modified on opening the drawing thinks it needs saving.
Is affected by the undo command, which Document.UserData isn't.
norman.yuan
You may want to check the system variable "DBMod":
You can also call Document.PopDbmod()/PushDbmod() to arbitrarily set the drawing modification status, if necessary.
See this documentation on these 2 methods (it is for AutoLisp, but the remark/code sample are straightforward to follow):
https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-1B34A525-A881-42A8-BD07-865CA685F33B
Norman Yuan
Drive CAD With Code
SRSDS
Hi Normal,
I was aware of the DBMOD system variable but never thought to try and change it.
I've just tried these which don't seem to work. That would be brilliant if I could achieve it.
        Application.DocumentManager.MdiActiveDocument.PopDbmod()
        Application.DocumentManager.MdiActiveDocument.PushDbmod()
        Application.SetSystemVariable("DBMOD", 0)
norman.yuan
If you read the LISP code sample referred in the link provided in my previous reply, you should realize the correct way to use PushDbmod()/PopDbmod() method:
You call PushDbmod() first, which is equivalent to save the DBMOD value; then you can go ahead to do your work with the drawing, which might result in the DBMOD value change accordingly; then you call PopDbmo() to remove the changed DBMO value caused by your code and restore the value when PushDbmod() is called.
So, you would use code like:
var dwg=.....MdiActiveDocument;
try
    dwg.PushDbmod();
   DoMyWorkToChangeThingsInDwg(dwg);
finally
    dwg.PopDbmod();
Norman Yuan
Drive CAD With Code
SRSDS
Thank you! I didn't think there would be a solution. That's great.
