Check if user has done something after opening a drawing.
SRSDS
Advisor Advisor
SRSDS
I would like a to know if the user has done something has occurred after a drawing has been opened.
I can't figure out a location to store a boolean variable that:
Does not modify the document's database. If the database is modified on opening the drawing thinks it needs saving.
Is affected by the undo command, which Document.UserData isn't.
Norman_Yuan
You may want to check the system variable "DBMod":
You can also call Document.PopDbmod()/PushDbmod() to arbitrarily set the drawing modification status, if necessary.
See this documentation on these 2 methods (it is for AutoLisp, but the remark/code sample are straightforward to follow):
https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-1B34A525-A881-42A8-BD07-865CA685F33B
Norman Yuan
Drive CAD With Code
SRSDS
Hi Normal,
I was aware of the DBMOD system variable but never thought to try and change it.
I've just tried these which don't seem to work. That would be brilliant if I could achieve it.
        Application.DocumentManager.MdiActiveDocument.PopDbmod()
        Application.DocumentManager.MdiActiveDocument.PushDbmod()
        Application.SetSystemVariable("DBMOD", 0)
Norman_Yuan
If you read the LISP code sample referred in the link provided in my previous reply, you should realize the correct way to use PushDbmod()/PopDbmod() method:
You call PushDbmod() first, which is equivalent to save the DBMOD value; then you can go ahead to do your work with the drawing, which might result in the DBMOD value change accordingly; then you call PopDbmo() to remove the changed DBMO value caused by your code and restore the value when PushDbmod() is called.
So, you would use code like:
var dwg=.....MdiActiveDocument;
try
    dwg.PushDbmod();
   DoMyWorkToChangeThingsInDwg(dwg);
finally
    dwg.PopDbmod();
Norman Yuan
Drive CAD With Code
SRSDS
Thank you! I didn't think there would be a solution. That's great.
