Check form loaded and hidden
SRSDS
Advisor Advisor
SRSDS
I am loading a form which is populated with several pictures and controls.
There is a small delay in it's loading so I would like to hide it and make it visible again.
How do I check if it's loaded?
            If SOMETHING Then
                FormShapes.Show()
            Else
                Application.ShowModalDialog(Application.MainWindow.Handle, FormShapes, False)
            End If
_gile
You can use a static (Shared) field to store the form instance that you initialize only once per session if it's null (Nothing).
        static Dialog formShapes = null;
        public static void SomeMethod()
            var doc = Application.DocumentManager.MdiActiveDocument;
            if (formShapes == null)
                formShapes = new Dialog(); // or whatever the form class name
Application.ShowModalDialog(doc.Window.Handle, formShapes, false);
Gilles Chanteau
GileCAD
GitHub
SRSDS
Thank you.
