change blockreference visibility using c#
1930331246064
1930331246064
I have created two visibilities VisibilityState0 and VisibilityState1 for a blockreference, now if i want to change the visibility of that block using c# code, how can i do it if I have a blockreference object?
_gile
You can use this method:
public static void SetDynamicPropertyValue(BlockReference block, string propName, object value)
    if (block.IsDynamicBlock)
        var props = block.DynamicBlockReferencePropertyCollection;
        foreach (DynamicBlockReferenceProperty prop in props)
            if (prop.PropertyName.Equals(propName))
                try
                    prop.Value = value;
                catch (System.Exception ex)
                    var ed = Application.DocumentManager.MdiActiveDocument.Editor;
                    ed.WriteMessage($"\n{ex.Message}");
                break;
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
My blockreference is not dynamic, then what to do?
ActivistInvestor
Visibility states only work with dynamic blocks. Other than attributes, non-dynamic blocks cannot have insertions that have a differing appearance.
