change any Entity layer
Amremad
Amremad
Hello
I need to Create a Function called ChangeLayer
public void ChangeLayer (Entity ent, string layerName)
// Here can i change layer
for any entity (Line, PLine, BlockReference, circle, .... )
_gile
What's wrong with simply doing:
ent.Layer = layerName;
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Amremad
🙂 sorry i missed
i meant how can i read the layer of block when i insert it from other drawing,
i mean i need to insert the block from other dwg with the same it's layer.
and can i use clone directly form other drawing to current ?? something like copy between drawings
_gile
Your request is not very clear.
You should post what you've written so far.
If you use the WBlockCloneObjects() with a BlockReference instance, you'll import also all symbolTableRecord instances (Layer, Linetype, etc.) linked to the block reference.
Gilles Chanteau
GileCAD
GitHub
Amremad
sorry about my english
i have Drawing 'A" has a block which is name "blk" and it;s layer is "my Layer" with color "1"
now iam opening Drawing "B" , i need to insert "blk" in drawing "B" with the same it's layer "my layer"
i hope now you understand me
_gile
What's confusing is the world "block" which may mean BlockReference or BlockTableRecord.
As you say: "a block which is name "blk" and it;s layer is "my Layer" " I suppose you're talking about a block reference (a BlockTableRecord, aka block definition, does not 'have' a Layer).
As said upper, if you 'WBlockClone' (i.e. deep cloning) a block reference, you also clone the Layer the block reference is inserted on.
Here's a little example:
        private static ObjectId ImportBlockReference(Database targetDb, string fileName, string blockName)
            using (var sourceDb = new Database(false, true))
                sourceDb.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, false, null);
                using (var tr = sourceDb.TransactionManager.StartOpenCloseTransaction())
                    var ms = (BlockTableRecord)tr.GetObject(
                        SymbolUtilityServices.GetBlockModelSpaceId(sourceDb), OpenMode.ForRead);
                    ObjectId brId = ObjectId.Null;
                    foreach (ObjectId id in ms)
                        if (id.ObjectClass.DxfName == "INSERT")
                            var br = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
                            if (br.Name == blockName)
                                brId = id;
                    if (!brId.IsNull)
                        var ids = new ObjectIdCollection();
                        ids.Add(brId);
                        var targetId = SymbolUtilityServices.GetBlockModelSpaceId(targetDb);
                        var mapping = new IdMapping();
                        sourceDb.WblockCloneObjects(ids, targetId, mapping, DuplicateRecordCloning.Ignore, false);
                        if (mapping[brId].IsCloned)
                            return mapping[brId].Value;
                return ObjectId.Null;
Running:
var id = ImportBlockReference(databaseOfDrawingB, @"A.dwg", "blk");
Will return the ObjectId of the cloned block reference in drawing B if a reference of "blk" have been found in drawing "A" model space.
Gilles Chanteau
GileCAD
GitHub
Amremad
yes that what i need exactly 🙂
thanks for your help
