Catch entities which intersected with a polyline
Hi All,
I have good experince with VB.Net, But i am new in prgramming for Autocad .
I had wrote code that catch all polylines on drawing, but now i have a  problem, i need to catch that entities (blocks in my case) which intersected  with each polyline.
any help please.
Thank you in advance.
Hi , to get intersection point between to entities you have to use 'entity.IntesectWith' function. With this function, you can get intersecting point. if for an entity if you get intersection point , you can add that entity in your list or array. you can have a look on below link where you can find how intersection point can be found between 2 entities.
http://forums.autodesk.com/t5/NET/Find-intersection-point-of-two-lines/m-p/4769671#M38812
Thank you very much Mr. mzakiralam
This is good try.
I know how to get intersection points using (IntersectWith) function, My problem is how to specify the type of the entity that intersects with the polyline.
 entity.GetType() will help you to get entity type. you can also use below function.
Dim ent as entity = transaction.GetObject(ObjectId, OpenMode.Write)
If TypeOf ent is Polyline
'do as you want
End If
