Capture brand new thumbnail of DWG on (side) database
BestFriendCZ
BestFriendCZ
Hi all,
i would like to use similar command without opening document
db.ThumbnailBitmap = doc.CapturePreviewImage(height, width);
Did someone test this? or is it even possible?
BestFriendCZ
Hi all,
i would like to try update this question? Is there anybody who knows how to update document preview on database side (ReadDwgFile)?
Is there even possible (I spend some time on that and didn't find solution)?
_gile
You can get a DWG thumbnail from outide of AutoCAD.
Code inspired by this topic.
        static Bitmap GetBitmap(string fileName)
            using (FileStream fs = new FileStream(fileName, FileMode.Open, FileAccess.Read, FileShare.ReadWrite))
            using (BinaryReader br = new BinaryReader(fs))
                fs.Seek(0xD, SeekOrigin.Begin);
                fs.Seek(0x14 + br.ReadInt32(), SeekOrigin.Begin);
                byte bytCnt = br.ReadByte();
                if (bytCnt <= 1)
                    return null;
                for (short i = 1; i <= bytCnt; i++)
                    byte imageCode = br.ReadByte();
                    int imageHeaderStart = br.ReadInt32();
                    int imageHeaderSize = br.ReadInt32();
                    if (imageCode == 6)       //PNG Preview (2013 file format);
                        fs.Seek(imageHeaderStart, SeekOrigin.Begin);
                        using (var ms = new MemoryStream())
                            fs.CopyTo(ms, imageHeaderStart);
                            var img = Image.FromStream(ms);
                            return new Bitmap(img);
            return null;
Gilles Chanteau
GileCAD
GitHub
BestFriendCZ
Hi _gile,
thank you for your feedback.
you are correct. Problem is that my question was not that specific ... sorry for that.
I know about this way how to read preview but i need capture brand new preview.
Situation like:
1) you do some changes on database side (changes which affect model)
2) and you need to create brand new thumbnail
I didn’t find way hot to achieve without open in CAD.... so i don’t know if it is even possible
Norman_Yuan
You question inspired me to write some code that could be the solution for you. I post the code in my block here:
https://drive-cad-with-code.blogspot.com/2022/08/generating-drawing-thumbnailpreview.html
Hope it helps.
Norman Yuan
Drive CAD With Code
BestFriendCZ
Hi Norman,
this is exactly which i need it.
I spent lots of time trying to achieve something like that. Thank you
