Cannot see the words when I type command
Message 1 of 12
Hello,My Autocad crashed while working and after rebooting and saving recovery file I am not able to see the words when I type any command. I can select objects and all the tools etc are working.
Replies (11)
Message 2 of 12
can you upload a snapshots?
Message 3 of 12
No
Message 4 of 12
How can we help you better if you can't even share the window for us to understand what was the problem really is?
anyway, I have some question.
But the command line is still there?you just can't see the command word you were typing?
Message 5 of 12
Sorry! I misunderstood! When I type my command nothing shows up on the screen. Hence sending a snapshot would be a blank screen only. But the command works in the sense the action takes place -for instance if I type "M" then I am able to move objects when I select them. The  problem is when it is commands like "Scale" I cant see the options which you normally can when you see the command you type.
Message 6 of 12
_gile
Are you talking about the 'dynamic input'? If so, just hit the F12 function key to turn it on.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 7 of 12
Hello @Anonymous
but the command line(Ctrl+ 9) is still there in your screen?
maybe your problem is the dynamic input(F12 to activate). (see image)
Message 8 of 12
Yay! Thanks! It worked!
Yes- Dynamic input was off and I turned it on again. For some reason F12 did not work.
Message 9 of 12
Welcome!!!
We're just right here to help!
Message 10 of 12
Thank you, I had the same issue and have been fixed by your instructions 😊
Message 11 of 12
Message 12 of 12
It worked. Thanks
