Cannot save drawing with user defined property sets in autocad MEP
I am adding blockreferences to a drawing from Excel with a plugin i created. I attach a self-defined property set called "Elektroteknikk" to the references but when i try to save the drawing i get the following error:
"One or more objects in this drawing cannot be saved to the specified format. The operation was not completed and no file was created"
I am using the standard aecpropdatamdg dll.
But when i manually attach the propertysetdefinition to the blockreferences in autocad i am able to save the drawing.
This is the code i am using to attach the propertysetdef and values to the blockrefrence
if (PropDefValues != null)
                var propSetDef = (PropertySetDefinition)PropDefValues[-1];
                using (Transaction tr2 = db.TransactionManager.StartOpenCloseTransaction())
                    PropertyDataServices.AddPropertySet(br, propSetDef.Id);
                    tr2.Commit();
                var propSetId = PropertyDataServices.GetPropertySet(br, propSetDef.Id);
                using (var propSet = (PropertySet)tr.GetObject(propSetId, OpenMode.ForWrite, false))
                    foreach(var KVPair in PropDefValues)
                        if(KVPair.Key != -1)
                            propSet.SetAt(KVPair.Key, KVPair.Value);
ANY help??
I managed to solve it. I forgot to convert DBNull values to null at one point in my code.
