Can't use function GetBoundingBox from C# application
Hi.
I work with Autocad from C# application using late binding.
After inserting block, i want to get its bounds.
double[] aMinPoint = new double[3], aMaxPoint = new double[3];
Params = new object[] { aMinPoint, aMaxPoint };
oBlock.GetType().InvokeMember("GetBoundingBox", BindingFlags.InvokeMethod, null, oBlock, Params);
But after execution this code aMaxPoint and aMinPoint had their default values - 0.
What do I do wrong?
By the way the same task in VB.NET (with built-in late binding) solves good.
Dim aMinPoint() As Double
Dim aMaxPoint() As Double
oBlock.GetBoundingBox(aMinPoint, aMaxPoint)
Thanks for help.
See the sample code here:
http://www.caddzone.com/LateBoundComSample.cs
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6326932@discussion.autodesk.com...
Hi.
oBlock, Params);
0.
What do I do wrong?
Thanks for help.
Perfect sample, thanks.
amitnkukanur
Can you share a copy of part of code because am unable to find data in the link. Am also using the same concept of GetBoundingBox to Get the location of Texts.
Senior Software Engineer
Virupaksha_aithal
Autodesk Support
Autodesk Support
Hi
refer blog post http://adndevblog.typepad.com/autocad/2012/07/using-activex-api-getboundingbox-in-net.html. The post shows the use of GetBoundingBox in c#  application
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
amitnkukanur
Hello Virupaksha.aithal, i resolved this issue quite some time ago, but stuck up in a new location. Call rejected by callee.
I have already posted a issue in the forum and side by side i am also trying to execute this, but my code gets stuck at Call rejected by callee.
Then if i press F5 it works as expected
http://forums.autodesk.com/t5/NET/Call-Rejected-by-Callee/td-p/3558826
This is the link for it
With Warm Regards
Amit
