Can't find ModelessOperationWill Start Event in Dot net
JanetDavidson
Message 1 of 21
JanetDavidson
Hello everybody. Hope somebody could help me
In objectArx  Editor  object has  ModelessOperationWillStart . But how could I use this in my vb net ?
ObjectBrowser doesn't show it ?!!!
Janet.
Replies (20)
Message 21 of 21
Alexander.Rivilis
This topic so old but today I've found another solution without using ObjectARX for checking OPM start/stop property editing.  It is look like this solution can be used with AutoCAD 2010+:
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Internal.PropertyInspector;
using System.Runtime.InteropServices.ComTypes;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(Rivilis.OPMReactors))]
namespace Rivilis
  public class OPMReactors
    [CommandMethod("OPMReactorsStart")]
    public void OPMReactorsStart()
      Document doc = Application.DocumentManager.MdiActiveDocument;
      if (doc == null) return;
      Editor ed = doc.Editor;
      PropertyInspectorEventManager pim = PropertyInspectorEventManager.Instance();
      pim.propertyWillChange += propertyWillChange;
      pim.propertyChanged += propertyChanged;
    [CommandMethod("OPMReactorsStop")]
    public void OPMReactorsStop()
      pim.propertyWillChange -= propertyWillChange;
      pim.propertyChanged -= propertyChanged;
    private void propertyChanged(object sender, PropertyInspectorEventArgs e)
      ed.WriteMessage("\npropertyChanged");
    private void propertyWillChange(object sender, PropertyInspectorEventArgs e)
      ed.WriteMessage("\npropertyWillChanged");
Facebook | Twitter | LinkedIn
Expert Elite Member
