C3D 2022, No Function Definition with LispFunction
CodeDing
Advisor Advisor
CodeDing
Hey All,
I'm hoping this can be an easy fix for some of you experts. I'm by no means totally proficient with C#/.NET/Visual Studio yet. Trying to get better. Anyways...
In short.. Trying to create a Lisp Function via .NET (C#). I've created some Lisp Functions via this API in the past, but now that I've switched over to Civil 3D I can't seem to get something right?
I have a SIMPLE method / function:
using System;
using System.Windows;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
namespace Test
    public class Testing
        [LispFunction("test")]
        public static void RunTest(ResultBuffer rbArgs)
            Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Hello World!");
There are no build errors:
I believe I have all the correct dependencies referenced:
Yet, when I run the function, it does not exist:
Please can I get some advice to get over this hurdle?
...About:
Best,
~DD
_gile
Is Copy Local property equal to False for each AutoCAD reference ?
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
CodeDing
Correct, they are all set to "No".
norman.yuan
@CodeDing ,
I think you started a wrong project type with your Visual Studio (2022, it looks to me). I tell this from 2 pictures you attached in your post.
1. The picture in your first post showing the references, it shows as "Dependencies", rather than "References" a it is supposed to be;
2. The picture attached to your reply to @_gile shows "Copy Local" to "No", rather "False" as it is supposed to be.
These 2 things indicate that you have chosen the project as .NET Core (.NET5/6), rather than .NET framework (4.7x/8). AutoCAD .NET API CAN ONLY work with .NET Framework, not .NET Core/5/6. You need to recreate your class library project as .NET Framework class library.
Norman Yuan
Drive CAD With Code
CodeDing
@norman.yuan ,
You are exactly correct. I did not know that. Thank you very much!
Best,
~DD
