[C#] Run AutoCAD
[C#] Run AutoCAD
m-d
[C#] Run AutoCAD
m-d
I tryed to run AutoCAD with codes like:
Process myProc8;
myProc8 = Process.Start(@"C:\Program Files\AutoCAD 2010\acad.exe");
or:
System.Diagnostics.Process.Start(@"C:\Program Files\AutoCAD 2010\acad.exe");
or:
Process p = new Process();
p.StartInfo.FileName = @"C:\Program Files\AutoCAD 2010\acad.exe";
p.Start();
But when AutoCAD starts, show the error, see the attachment "p1", and in command line, see the attachment "p2".
How to start AutoCAD with no error and/or with a profile,...
m-d
Change the debug to release, tryed to run from bin file,... result is the same. Anyone?
OysteinW
I don't know about the second error, but I got the first error recently because I was debugging inside Civil3d while the "Working Directory"-folder in debug-settings was set to AutoCAD install folder.
Try setting "working directory" to "C:\Program Files\AutoCAD 2010\"
-Øystein
m-d
OysteinW
I haven't tried starting AutoCAD from an external process like you seem to do here, but the error message is the same.
-Wich was resolved by setting working directory in debug settings for my project, or by setting working directory in the shortcut wich starts my program..
But I guess this is equivalent to:
            p.StartInfo.WorkingDirectory = @"C:\Program Files\AutoCAD 2010\";
            p.Start();
            Process p = new Process();            p.StartInfo.WorkingDirectory = @"C:\Program Files\AutoCAD 2010\";
            p.StartInfo.FileName = @"C:\Program Files\AutoCAD 2010\acad.exe";            p.Start();
(But I haven't tested it).
m-d
I can`t beleve it! It`s working! No errors! Thanks!
