c# pallete create
c# pallete create
Message 1 of 20
c# pallete create
hello kean if you have me in c # environment send autocad palette creation file I need this much mail address [email protected]
Replies (19)
Message 2 of 20
_gile
A good practice should be:
  1. Define the commands (PC, Method1, Method2, Method3, Method4 and TEST) decoring them with the CommandMethod attribute so that they work as expected when called from AutoCAD Command line.
  2. Add a UserControl to the project with the buttons and define the Click handler of each button to launch the corresponding command with SendStringToExecute() method.
  3. Define a class deriving from PaletteSet to host the UserControl.
  4. Define a command to show the palette.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 20
_gile
Here's a short example
The Commands class
    public class Commands
        [CommandMethod("PC")]
        public void Pc()
            // here the code of the PC command
        [CommandMethod("Method1")]
        public void Method1()
            // here the code of the Method1 command
        [CommandMethod("Method2")]
        public void Method2()
            // here the code of the Method2 command
        [CommandMethod("Method3")]
        public void Method3()
            // here the code of the Method3 command
        [CommandMethod("Method4")]
        public void Method4()
            // here the code of the Method4 command
        [CommandMethod("TEST")]
        public void Test()
            // here the code of the TEST command
        static CustomPaletteSet palette;
        [CommandMethod("CMDPALETTE")]
        public void CmdPalette()
            if (palette == null)
                palette = new CustomPaletteSet();
            palette.Visible = true;
The Palettetab class (UserControl)  with the buttons event handlers
    public partial class PaletteTab : UserControl
        public PaletteTab()
            InitializeComponent();
        private void btnPc_Click(object sender, EventArgs e)
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            if (doc != null)
                doc.SendStringToExecute("PC ", false, false, true);
        private void btnMethod1_Click(object sender, EventArgs e)
            if (doc != null)
                doc.SendStringToExecute("Method1 ", false, false, true);
        private void btnMethod2_Click(object sender, EventArgs e)
            if (doc != null)
                doc.SendStringToExecute("Method2 ", false, false, true);
        private void btnMethod3_Click(object sender, EventArgs e)
            if (doc != null)
                doc.SendStringToExecute("Method3 ", false, false, true);
        private void btnMethod4_Click(object sender, EventArgs e)
            if (doc != null)
                doc.SendStringToExecute("Method4 ", false, false, true);
        private void btnTest_Click(object sender, EventArgs e)
            if (doc != null)
                doc.SendStringToExecute("TEST ", false, false, true);
The CustomPaletteSet class
    public class CustomPaletteSet : PaletteSet
        public CustomPaletteSet()
            : base("COMMANDS", "CMDPALETTE", new Guid("{CB44AAE8-B3C8-4F97-817B-D5F96FDB3C1C}"))
            Style = PaletteSetStyles.ShowAutoHideButton |
                    PaletteSetStyles.ShowCloseButton |
                    PaletteSetStyles.ShowPropertiesMenu;
            MinimumSize = new System.Drawing.Size(150, 220);
            Add("Tab", new PaletteTab());
Gilles Chanteau
GileCAD
GitHub
Message 4 of 20
do you have a situation to mail me in a form of example I do not know too much yemiyorum mail can [email protected]
Message 5 of 20
_gile
I can try to help you here, in the forum, but I won't  communicate by mail.
If you clearly expose what you're trying to achieve, and show what you have done so far, you should get help from more people and every one could benefit of the discussion.
Gilles Chanteau
GileCAD
GitHub
Message 6 of 20
I would like to add the palette creation phase as a video, which is more useful, I add the code, it gives an error, thank you very much for your video.
Message 7 of 20
_gile
If you want to get some help, please, give more precision about what you're already able to do and what you need help for.
Gilles Chanteau
GileCAD
GitHub
Message 8 of 20
you will correct the mistakes in the article you added to the form and add the final form to you.
Message 9 of 20
you can correct the errors in the file and add the final state.
Message 10 of 20
I uploaded the wrong files. Could you upload these files to the forum after fixing these errors? I apologize for tiring you
Message 11 of 20
_gile
Obviously you are missing the basics of .NET programming.
You should not start by wanting to make a palette for AutoCAD, it's like trying to run before you know how to walk.
You should start by learning the basics of object-oriented programming with .NET and C # outside AutoCAD and only when you are comfortable with the basics you can start learning the AutoCAD API (you'll get learning material here and the documentation here).
I attached the corrected 'palet' solution
Gilles Chanteau
GileCAD
GitHub
Message 12 of 20
Thank you very much for the valuable information you give
Message 13 of 20
Hi @_gile ,
How to disable the menu bar as image below:
Message 14 of 20
_gile
As far as I know, you cannot. This is part of the PaletteSet.
Gilles Chanteau
GileCAD
GitHub
Message 15 of 20
Can you offer a series of "new Guid" like this?
new Guid("63B8DB5B-10E4-4924-B8A2-A9CF9158E4F6")
I think it can be done by changing this Guid.
Message 16 of 20
_gile
There are many free GUID generators on the web, you can also use the one provided by Visual Studio (Tools menu > Create GUID).
Gilles Chanteau
GileCAD
GitHub
Message 17 of 20
BlackBox_
Was reading through this old thread and saw this post by @_gile - if only @TimYarris & team adhered to Step #2 (invoking Commands from Palettes or Context MenuItem.Click() events, instead of simply calling the underlying Method) we'd be able to fix a lot of issues on our own, by simply Veto()-ing Commands, fixing the issue, then re-invoke same.
Cheers
"How we think determines what we do, and what we do determines what we get."
Chris (BlackBox) Bradley
Managing Partner / Developer / Civil Designer
Quux Software | Sincpac C3D | Style Explorer
Message 18 of 20
Norman_Yuan
@Anonymous
If you want a window floating(modeless) like PalatteSet, but no the frame of the PaletteSet, then why use PaletteSet? You can simply create a winForm/WPF window and show it as modeless dialog/window, whoch you can set the winform/wpf window as borderless (but you surely want provide a way for user to close/hide the form/window, don't you?).
Norman Yuan
Drive CAD With Code
Message 19 of 20
Hi @Norman_Yuan ,
Because the PaletteSet is always activate when autoCAD is activate and a winForm/WPF window is not.
I am looking for 2 solutions:
1. The PaletteSet without the Menu bar.
2. Setting winForm/WPF window always activate with autoCAD .
Currently I am using option 2:
I've set winForm/WPF window to always on top, but they're annoying when working with other programs. How to make winForm/WPF window always active when autoCAD is active?
Message 20 of 20
_gile
@Anonymous
As @Norman_Yuan already said, you have to show the dialog box as modeless dialog using either:
Application.ShowModelessDialog with a WinForms dialog
or:
Application.ShowModelessWindow with a WPF dialog.
Gilles Chanteau
GileCAD
GitHub
