C# .net Make a function that takes in CSV and draw lines
jeff.wangD95HG
Message 1 of 11
jeff.wangD95HG
Hello I am fairly new to C# .net programming and I want write a program that  will read CSV that contains
X starting, Y starting, X ending, Y ending and draw lines out of those information.
Basically take the starting coordinate and draw a line to the ending coordinate
Any pointers on how to get started? I already have the environment setted up already
Replies (10)
Message 2 of 11
_gile
In general, I recommend that anyone wanting to get started with C# should start by learning the basics of .NET C# programming outside AutoCAD before embarking on learning the AUtoCAD .NET API.
In your case, this is essential for certain tasks such as :
- reading a text file using a StreamReader instance (which will also give you an insight into the use of using statements).
- converting a character string containing data with a separator into a single-dimension array of strings using the String.Split method.
- parse a string representing a real number into a double using the double.Parse method.
Only once you've learned this can you use the data in AutoCAD to create lines.
- Start a new AutoCAD project
- Learn the basics of the AutoCAD API
- Create  AutoCAD entities
Gilles Chanteau
GileCAD
GitHub
Message 3 of 11
jeff.wangD95HG
I quickly gave my question to ChatGPT and this is what I got
using System;
using System.Collections.Generic;
using System.IO;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
public class LineDrawingUtils
[CommandMethod("DrawLinesFromCSV")]
public void DrawLinesFromCSV()
// Get the CSV file path from user input
string csvFilePath = GetFilePath("Select CSV File", "CSV Files (*.csv)|*.csv");
if (!string.IsNullOrEmpty(csvFilePath))
try
// Read the CSV file and draw lines
DrawLinesFromCSVData(csvFilePath);
catch (Exception ex)
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.Message);
private string GetFilePath(string prompt, string filter)
PromptOpenFileOptions options = new PromptOpenFileOptions(prompt, filter);
PromptFileNameResult result = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.GetFileNameForOpen(options);
return result.Status == PromptStatus.OK ? result.StringResult : string.Empty;
private void DrawLinesFromCSVData(string csvFilePath)
if (!File.Exists(csvFilePath))
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("CSV file not found.");
return;
using (Transaction transaction = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction())
using (StreamReader reader = new StreamReader(csvFilePath))
string line;
while ((line = reader.ReadLine()) != null)
string[] data = line.Split(',');
if (data.Length == 4 &&
double.TryParse(data[0], out double startX) &&
double.TryParse(data[1], out double startY) &&
double.TryParse(data[2], out double endX) &&
double.TryParse(data[3], out double endY))
Point3d start = new Point3d(startX, startY, 0);
Point3d end = new Point3d(endX, endY, 0);
DrawLine(start, end);
transaction.Commit();
private void DrawLine(Point3d startPoint, Point3d endPoint)
BlockTable blockTable = transaction.GetObject(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.BlockTableId, OpenMode.ForRead) as BlockTable;
BlockTableRecord modelSpace = transaction.GetObject(blockTable[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
Line line = new Line(startPoint, endPoint);
modelSpace.AppendEntity(line);
transaction.AddNewlyCreatedDBObject(line, true);
is that the correct syntax to read from file path?
Message 4 of 11
jeff.wangD95HG
using System;
using System.IO;
public class CsvLineDrawer
    public static void DrawLinesFromCsv(string csvFilePath)
            Console.WriteLine("CSV file not found.");
            return;
        using (var reader = new StreamReader(csvFilePath))
            while (!reader.EndOfStream)
                var lineData = reader.ReadLine();
                var values = lineData.Split(',');
                if (values.Length == 4 &&
                    double.TryParse(values[0], out double xStart) &&
                    double.TryParse(values[1], out double yStart) &&
                    double.TryParse(values[2], out double xEnd) &&
                    double.TryParse(values[3], out double yEnd))
                    DrawLine(xStart, yStart, xEnd, yEnd);
    private static void DrawLine(double xStart, double yStart, double xEnd, double yEnd)
        Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
        Database db = doc.Database;
        Editor editor = doc.Editor;
        using (Transaction tr = db.TransactionManager.StartTransaction())
            BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
            BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
            Point3d startPoint = new Point3d(xStart, yStart, 0);
            Point3d endPoint = new Point3d(xEnd, yEnd, 0);
            using (Line line = new Line(startPoint, endPoint))
                btr.AppendEntity(line);
                tr.AddNewlyCreatedDBObject(line, true);
            tr.Commit();
generated it again today, but this time the functions are more familiar to me
Message 5 of 11
jeff.wangD95HG
using System;
using System.IO;
    [CommandMethod("DrawLinesFromCsv")]
    public void DrawLinesFromCsv()
        // Get the CSV file path from the user using AutoCAD file dialog
        string csvFilePath = GetCsvFilePath();
            else
                ProcessCsvFile(csvFilePath);
    private string GetCsvFilePath()
        // Use AutoCAD's file dialog to select the CSV file
        Editor editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
        PromptOpenFileOptions openOptions = new PromptOpenFileOptions("Select CSV File");
        openOptions.Filter = "CSV Files (*.csv)|*.csv";
        PromptFileNameResult result = editor.GetFileNameForOpen(openOptions);
        if (result.Status == PromptStatus.OK)
            return result.StringResult;
        return null;
    private void ProcessCsvFile(string csvFilePath)
    private void DrawLine(double xStart, double yStart, double xEnd, double yEnd)
            tr.Commit();
ok several back and forth with chat GPT and this end up being the result.
works great in the first few attempts. But still require further testing.
Message 6 of 11
kerry_w_brown
@jeff.wangD95HG
Can you please format the code by using the 'Insert/Edit code sample' button with language set to C#
Do you have a record of the questions you asked the AI for each response ??
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 7 of 11
jeff.wangD95HG
JULY 26
"write me a function in C# .net for civil 3d that reads CSV containing X start, Y start, X end, and Y end and draw a line according to those information"
regenerate response
"make it so I can call the function from civil 3d"
each correspond to the code that was posted
I need some help on how to insert format option on this forums
Message 8 of 11
Ed__Jobe
To edit a post, click on the 3 vertical dots in the upper right of the post and select Edit Reply. Cut the code from the post. Click on the </> button to open the code window. If the button isn't visible, click on the three horizontal dots to show more command buttons. Paste the code into the code window. Select C# as the language format and click OK.
Ed
How to post your code.
Message 9 of 11
_gile
IMHO, if you want to learn AutoCAD programming keep far away from ChatGPT (or any other chatbot) and write code by yourself.
Gilles Chanteau
GileCAD
GitHub
Message 10 of 11
jeff.wangD95HG
Well I think this is like having answers at the back of the text book.
I don't think its worthwhile banging your head without any ideas of what the answers look like. If you know seen enough examples and reversed engineered enough solutions you should get better. But if you just copied the answers to the back of the text book without doing any additional work, of course you are not going to learn anything.
I already have a good basic understanding of coding in python and C++ I am just not aware of the syntax and tools that are available to use in C# and civil api
Message 11 of 11
kerry_w_brown
No, not really.
It's more like getting someone else to do your homework.
If it was the back of the textbook you could be more comfortable that the answer may be correct.
but, to each his own  🙂
