C# - Hatching a block reference.
jlobo2
Message 1 of 8
jlobo2
I want to hatch a block reference shown below. I am able to hatch it in solid, but the hatching is displaced by x distance and y height. I feel it's something related to z axis but I am not able to figure it out.
Can you please suggest something.
Special shout out to @Alexander.Rivilis
Code is below:
public void ColorBlock(ObjectId thePANBLKBlockTableRecord, short colorIndex)
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                // Check to make sure a valid SelectedObject object was returned
                if (thePANBLKBlockTableRecord != null)
                    try
                        Entity ent = (Entity)tr.GetObject(thePANBLKBlockTableRecord, OpenMode.ForWrite);
                        // Should always be a block reference, but let's make sure
                        BlockReference br = ent as BlockReference;
                        if (br != null)
                            // Change the color of the block itself
                            br.UpgradeOpen();
                            br.ColorIndex = colorIndex;
                            // Change every entity to be of color ByBlock
                            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(
                                br.BlockTableRecord, OpenMode.ForWrite);
 #region Square
                            Point2d pt = new Point2d(br.Position.X, br.Position.Y);
                            Autodesk.AutoCAD.DatabaseServices.Polyline plBox =
                                new Autodesk.AutoCAD.DatabaseServices.Polyline(4);
                            plBox.Normal = Vector3d.ZAxis;
                            plBox.AddVertexAt(0, pt, 0.0, 0, 0);
                            plBox.AddVertexAt(1, new Point2d(pt.X + 4, pt.Y), 0.0, 0, 0);
                            plBox.AddVertexAt(2, new Point2d(pt.X + 4, pt.Y + 4), 0.0, 0, 0);
                            plBox.AddVertexAt(3, new Point2d(pt.X, pt.Y + 4), 0.0, 0, 0);
                            plBox.Closed = true;
                            ObjectId pLineId;
                            pLineId = btr.AppendEntity(plBox);
                            tr.AddNewlyCreatedDBObject(plBox, true);
                            ObjectIdCollection acObjIdColl = new ObjectIdCollection();
                            acObjIdColl.Add(pLineId);
                            Hatch oHatch = new Hatch();
                            Vector3d normal = new Vector3d(0,0, 1);
                            oHatch.Normal = normal;
                            oHatch.Elevation = 0.0;
                            oHatch.PatternScale = 2;
                            oHatch.SetHatchPattern(HatchPatternType.PreDefined, "SOLID");
                            oHatch.ColorIndex = colorIndex;
                            btr.AppendEntity(oHatch);
                            tr.AddNewlyCreatedDBObject(oHatch, true);
                            oHatch.Associative = true;
                            oHatch.AppendLoop((int)HatchLoopTypes.Default, acObjIdColl);
                            oHatch.EvaluateHatch(true);
                            #endregion
#endregion
                            #region Color the boundary red
                            // Iterate through the BlockTableRecord contents
                            foreach (ObjectId id in btr)
                                // Open the entity
                                Entity ent2 = (Entity)tr.GetObject(id, OpenMode.ForWrite);
                                // Change each entity's color to ByBlock
                                ent2.Color = Color.FromColorIndex(ColorMethod.ByBlock, colorIndex);
                            #endregion
                    catch (Autodesk.AutoCAD.Runtime.Exception e)
                        ed.WriteMessage(e.ToString());
                tr.Commit();
Replies (7)
Message 2 of 8
Alexander.Rivilis
You have to take into account the conversion of the WCS in OCS. br.BlockTransform.Invert return such matrix.
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 8
jlobo2
Ok, Thank You @Alexander.Rivilis
Once I do the block transform, how do I access those co-ordinates?
Message 4 of 8
Alexander.Rivilis
You have not transform block, but you have to transform coordinates with this transformation matrix.
Expert Elite Member
Message 5 of 8
jlobo2
Ok. @Alexander.Rivilis ,
If you don't mind can you help me out with some code.
Currently I am trying to to this:
 Matrix3d tempMatrix = br.BlockTransform.Inverse();
 Point2d pt =
    new Point2d(
         tempMatrix.CoordinateSystem3d.Origin.X,
         tempMatrix.CoordinateSystem3d.Origin.Y);
         plBox.Normal = new Vector3d(0, 0, 1); //Vector3d.ZAxis;
         plBox.AddVertexAt(0, new Point2d(pt.X , pt.Y  ), 0.0, 0, 0);
         plBox.AddVertexAt(1, new Point2d(pt.X + 4, pt.Y ), 0.0, 0, 0);
Message 6 of 8
Alexander.Rivilis
Totally wrong.  You have to use pt.TransformBy() method (but instead of Point2d you have to use Point3d)
Expert Elite Member
Message 7 of 8
jlobo2
Ok, @Alexander.Rivilis
Something like this?
PlanarEntity tempPlanarEntity = br.GetPlane();
Point2d pt2D =
     new Point2d(
Point3d pt3D = new Point3d(tempPlanarEntity, pt2D);
     plBox.AddVertexAt(0, new Point2d(pt3D.X , pt3D.Y  ), 0.0, 0, 0);
     plBox.AddVertexAt(1, new Point2d(pt3D.X + 4, pt3D.Y ), 0.0, 0, 0);
     plBox.AddVertexAt(2, new Point2d(pt3D.X + 4, pt3D.Y + 4), 0.0, 0, 0);
     plBox.AddVertexAt(3, new Point2d(pt3D.X, pt3D.Y + 4), 0.0, 0, 0);
Message 8 of 8
jlobo2
Great, @Alexander.Rivilis
I got that to work. Thank You for your help.
Getting the plane worked.
