C# COM API: Intersection / Interference of Solid and Surface
I want to control AutoCAD via the COM API in C# (an out-process app) and get possible intersections / interference objects of an AutoCAD.AcadSurface and AutoCAD.Acad3DSolid.
I tried several methods but none works:
  • Acad3DSolid.CheckInterference(AcadSurface, false, out bool interference) => won't compile because this method only wants to take another 3dSolid
  • Acad3DSolid.Boolean() => same as above
  • AcadSurface.IntersectWith(Acad3DSolid, AutoCAD.AcExtendOption.acExtendNone) => exception from HRESULT: 0x80200001
  • Acad3DSolid.IntersectWith(AcadSurface, AutoCAD.AcExtendOption.acExtendNone) => throws an exception: "Not yet implemented"
In .NET API (in-process) there is a method Surface.createInterferenceObjects() (see here: https://forums.autodesk.com/t5/net/solid3d-checkinterference-overload-with-other-entities-e-g/m-p/82...)
In C++ ObjectARX there is also a method AcDbSurface::createIntereferenceObjects() (see here: https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2017/ENU/OARXMAC-RefGuide/file...)
Is there a way to do this in COM API in C#? I would be very happy if someone could help me. Many thanks in advance.
I use AutoCAD Mechanical 2019 and Windows 10.
Alexander.Rivilis
Sorry for bad news but in COM API there is no methods for that. But you can create arx-plugin, load it into AutoCAD and communicate with it.
AcDbSurface::createInterferenceObjects and AcDbSurface::booleanIntersect methods can help you.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Thank you very much for your quick answer.
I will try to use another solid instead of a surface then.
I chose to use the COM API instead of the .NET API (for an in-process app) because it gives me full control over AutoCAD. What I need to do is insert a solid and get the return value from the interference method and I prefer to let my out-process app control the inputs and outputs instead of handing it over to AutoCAD, executing a custom command and then reading some user variable. (I tried this and find it a bit unsatisfying.)
And I don't know any C++ yet.
Alexander.Rivilis
1. AutoCAD COM/ActiveX API has not been developed for more than 10 years.
2. Out-process is much slower than In-process
I think in your case you can use AcCoreConsole. You can start it from your external application and load .NET-plugin into it to use all functionality of AutoCAD .NET API instead of COM API. This is the fastest and most effective method. IMHO.
Expert Elite Member
