06:39 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Guys,
This is what I am trying to do,
- Access a remote dwg and get the lsit of layers
- Check if the layers exists in the current drawing
- Create the layers (bulk)
I am able to first two points, last point is there AutoCAD crahsing.
I have a collection of layertablerecord. Which says the count is 4 when do a foreach on that to read the layer names it is crashing autocad.
List<LayerTableRecord> layers = new List<LayerTableRecord>();
layers = Helper.CADHelper.GetLayerfromDWG(GV.dwgTemplatePath, layernames);public static void AddLayersToCurrentDrawing(List<LayerTableRecord> layerList)
if (layerList == null)
throw new ArgumentNullException("layerList");
if (layerList.Count == 0)
throw new ArgumentOutOfRangeException("layerList");
var curDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
if (curDoc == null)
throw new ArgumentNullException("MdiActiveDocument");
var curDb = curDoc.Database;
try
using (var trans = curDb.TransactionManager.StartOpenCloseTransaction())
var layerTable = (LayerTable)trans.GetObject(curDb.LayerTableId, OpenMode.ForWrite);
foreach (var layer in layerList)
if (layerTable.Has(layer.Name))
continue;
layerTable.Add(layer);
trans.AddNewlyCreatedDBObject(layer, true);
trans.Commit();
catch (Autodesk.AutoCAD.Runtime.Exception ex)
System.Diagnostics.Debug.Write(ex.ToString());
curDoc.Editor.WriteMessage(ex.ToString());
catch (SystemException ex)
}it is crashing at the highlighted line. When creating layer.
Please advise.
