Break points not stopping code on modeless forms
JamesMaeding
Advisor Advisor
JamesMaeding
I am using acad 2012, and VS 2010 (C#) on win 7 64 bit.
I made a form, and showing it as modeless via Application.ShowModelessDialog... as recommended by everyone and that works fine.
I have a button that does something, and I set a break point right on the first line of code for its callback.
The button runs fine, but VS is not stopping at the break point.
Is there a different technique required when debugging modeless forms?
thx
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Alfred.NESWADBA
have you set Framework4 as the current Framework for your project?
If you don't want FW4 then a good point to look at: >>>here<<<
And NEXTFIBERWORLD could be a point-of-interest, look to >>>this issue<<<
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
JamesMaeding
yah, setting framework to 4 did the trick.
The other options Kean mentioned are less desirable.
Wish I could stick with 3.5, as 4 is not always on a given machine.
Guess I can switch back before deploying.
Thanks a bunch for your reply, i was worried about this last night.
Alfred.NESWADBA
If AutoCAD 2012 is installed, then Framework 4 is installed, it does not run without! 😉
- alfred -
Alfred NESWADBA
JamesMaeding
I lose track of what needs what. I program for 2009 and 2012 so I will just target each project for correct framework.
thx
Alfred.NESWADBA
check the bottom of >>>this link<<<
...and for 2012 you need 4.0
- alfred -
Alfred NESWADBA
