BlockTableRecord.Erase not deleting block
Bradleywalker12380
Message 1 of 8
Bradleywalker12380
I am trying to delete a specific block, I am using BlockTableRecord.Erase, and when I open the DWG the block is still there even though when I debug it specifically makes it past that line.
What am I doing wrong?
After BlockTableRecord.Erase, I did oDb.Purge for that BlockTableRecord.ObjectID
Replies (7)
Message 2 of 8
_gile
What do you mean? BlockReference or BlockTableRecord?
Erasing a BlockTableRecord means purging the block definition and cannot be done if the BlockTableRecord is referenced (i.e. there's any BlockReference in the drawing).
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
Bradleywalker12380
This is what I am doing, and the block is still there after I have deleted it.
Message 4 of 8
_gile
You are doing things the wrong way. You should read more attentively the documentation about the Database.Purge method.
First you have to check if the BlockTableRecord is not referenced with Database.Purge, and then, if it is not, delete it.
var ids = new ObjectIdCollection();
ids.Add(btr.ObjectId);
db.Purge(ids);
if (ids.Count == 1)
    btr.Erase();
PS: typically we use br as variable name for a BlockReference instance and btr for a BlockTableRecord instance.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 8
Bradleywalker12380
Thank you, I did try that and I see that the count is still = 0.
How can I delete the block before it is checked to be purged?
Message 6 of 8
_gile
That means the BlockTableRecord is referenced, i.e. there's one or more reference to this definition inserted in the drawing.
You cannot delete a BlockTableRecord (as any SymbolTableRecord) while it is referenced, which means, in AutoCAD drafter languauge : you cannot purge a block (as a layer, a linetype, ...) while it is used in the drawing.
To be able to erase the BlockTableRecord, you have to first erase all its BlockReferences.
You can get the existing references with the BlockTableRecord.GetBlockReferenceIds method.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 8
Bradleywalker12380
Thank you, I did that and was able to delete the block.... but since the block was nested it also deleted the entire block using .GetBlockReferenceIds(directOnly:=False, forceValidity:=True)
When I did .GetBlockReferenceIds(directOnly:=True, forceValidity:=True) it didnot delete the block.
I read the link about .GetBlockReferenceIds and I believe it t should be False, False.
Correct?
Message 8 of 8
Bradleywalker12380
I *think* I got it...?
So from the IDs returned in (GetBlockReferenceIds,False, False) I check and get the owner BTR from the ID as a BlockReference, and then check if .IsLayout = False.
It works, but I have a feeling this isn't the best way to see if it is a nested block.
Can anyone confirm this please?
Thanks!
-B
