BlockReferences, prevent scale command and to modify scale properties
E3DE
E3DE
is there a way to prevent scale by command or by properties on block references with a specific xRecord associated?
Thank you
norman.yuan
Overrule might be the thing to look into (TransformOverrule).
However, before trying to develop a complicated code solution, I'd first look into the possibility of implementing basic "best practice"/office standard to deal this, such as place these block references (or whatever entities) on a locked layer - straightforward and easy solution.
Norman Yuan
Drive CAD With Code
E3DE
Thank you
