BlockReference SubEntities
HJohn1
HJohn1
I need to get the bounding box Min and Max points of a rectangle inside a BlockReference.  I have tried to get the sub entities thru the BlockRecord and then go thru the vertices of the rectangle (Polyline).  However, since this BlockReference is part of a title block in a drawing template, I would also have to deal with the drawing scale, the title block is in the model space.  See attached picture.  I just wandering if there is an easier way to achieve this. I will really appreciate any help.
_gile
After getting the coordinates in the BlockTableRecord, you can transform them using the BlockReference.BlockTransform matrix.
Gilles Chanteau
GileCAD
GitHub
HJohn1
Gile, thank you very much for your help, it has been really appreciated.
can you post your source code please,
i am trying to get the name of the Reference Block in the Model space but i couldn't achieve that.
marcin.sachs
@Anonymous
You can get the block name using this:
[CommandMethod("blockName")]
static public void blockName()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    PromptEntityOptions options =
             new PromptEntityOptions("\nSelect block reference");
    options.SetRejectMessage("\nSelect only block reference");
    options.AddAllowedClass(typeof(BlockReference), false);
    PromptEntityResult acSSPrompt = ed.GetEntity(options);
    using (Transaction tx =
                        db.TransactionManager.StartTransaction())
        BlockReference blockRef = tx.GetObject(acSSPrompt.ObjectId,
                               OpenMode.ForRead) as BlockReference;
        BlockTableRecord block = null;
        if (blockRef.IsDynamicBlock)
            //get the real dynamic block name.
            block = tx.GetObject(blockRef.DynamicBlockTableRecord,
                    OpenMode.ForRead) as BlockTableRecord;
        else
            block = tx.GetObject(blockRef.BlockTableRecord,
        if (block != null)
            ed.WriteMessage("Block name is : "
                                        + block.Name + "\n");
        tx.Commit();
Thanks for your Suggestion,
I have to select the block reference, to get its name.
I got the list of the used blocks in the active dwg by this code.
[CommandMethod("REV1")]
        public void EditBlock1()
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = acDoc.Editor;
            var acDb = HostApplicationServices.WorkingDatabase;
            using (var acTrans = acDb.TransactionManager.StartTransaction())
                var acBlockTable =
                     acTrans.GetObject(acDb.BlockTableId, OpenMode.ForRead) as BlockTable;
                if (acBlockTable == null) return;
                var acBlockTableRecord = acTrans.GetObject(acBlockTable[BlockTableRecord.ModelSpace],
                if (acBlockTableRecord == null) return;
                foreach (ObjectId id in acBlockTableRecord)
                    string blockName;
                    BlockReference bref = acTrans.GetObject(id, OpenMode.ForRead) as BlockReference;
                    if (bref != null)
                        if (bref.IsDynamicBlock)
                            BlockTableRecord br = (BlockTableRecord)acTrans.GetObject(bref.DynamicBlockTableRecord, OpenMode.ForRead);
                            //blockName = br.Name;
                            blockName = "DynamicBlock";
                        else
                            blockName = bref.Name;
                        //Debug.WriteLine("Found block reference: " + blockName);
                        ed.WriteMessage("\n Found block reference:  {0}\n\n", blockName);
                acTrans.Commit();
