block textstring's width
i insert a block,and the block's textstirng is input by the user, and sometimes the textstring is a litter long, how do i judge the textstring is longer than the block's width. and in textstring,there may contain chinese charactor. thanks
cadMeUp
You can try this:
Autodesk.AutoCAD.GraphicsInterface.TextStyle txtStyle = new Autodesk.AutoCAD.GraphicsInterface.TextStyle();
txtStyle.StyleName = "Standard";
txtStyle.TextSize = 1.0;
txtStyle.XScale = 1.0;
txtStyle.Vertical = false;
Extents2d ext = txtStyle.ExtentsBox("TEXTSTRING", true, false, null);
double width = ext.MaxPoint.X - ext.MinPoint.X;
Thanks a lot
and i solve it in another way.
the width is fixed for a block, and the max bytes is also fixed,
so i use System.Text.Encoding.Default.GetByteCount(string) to count all words in bytes number including chinese charactor.
