Block reference without inserting or selecting
Rob.O
Message 1 of 11
Rob.O
Hi all!
I need help (in more ways than one my wife would say).
I am trying to get an existing block reference in my current document without a selection set and without inserting the block. So in other words, the block in question has previously been inserted into the drawing. I have found numerous examples on the forums, but all deal with either first inserting the block or using a selection set to get at it.
Everything works great until I try to declare myBlkRef.  Everytime I run the code, I get an "InvalidCastException" error on the second line of code shown below.  If I run the same code when using a selection set to select the block the code works fine.
I have no problem getting the blocktable, blocktablerecord or objectid of the block in question, but I cannot figure out how to cast it as a blockreference.
So, my basic question is, how do I get a blockreference that has already been inserted into a drawing without using a selection set??? My ultimate goal is to change it's attribute values.
Please forgive my ignorance... I am still trying to learn all of this blocktable, blocktablerecord, blockreference, objectid, etc... business.
Dim blkRefID As ObjectId
Dim myBlkRef As BlockReference = blkRefID.GetObject(OpenMode.ForRead)
TIA!
Replies (10)
Message 2 of 11
So the BlockTable holds all the BlockTableRecord's.  Once you are able to get the BTR, then you will be able to get all the BlockReference's from there, as the BTR has a method called GetBlockReferenceIds, which will return an ObjectIdCollection.  You can just step through the collection with a Foreach statement, and cast those ids to BlockReference's.
Hope that helps.
Message 3 of 11
This is exactly what t.willey said in the previous post, but also moves the blockreferences from a block named "C" for no reason at all
  <CommandMethod("GetAndMoveBlockReference")> _
        Public Sub GetAndMoveBlockReference()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using trx As Transaction = db.TransactionManager.StartTransaction()
                Dim bt As BlockTable = db.BlockTableId.GetObject(OpenMode.ForRead)
                Dim btrBlock As BlockTableRecord = bt("C").GetObject(OpenMode.ForRead)
                Dim brefIds As ObjectIdCollection = btrBlock.GetBlockReferenceIds(TrueTrue)
                For Each objId As ObjectId In brefIds
                    Dim bref As BlockReference = objId.GetObject(OpenMode.ForWrite)
                    bref.Position = bref.Position.TransformBy(Matrix3d.Displacement(New Vector3d(25, 25, 0)))
                Next
                trx.Commit()
            End Using
        End Sub
Message 4 of 11
Rob.O
Thanks folks!  The above worked perfectly!
Now on to my next question... the above code works great for a single block, but what if I want to itterate more than one block?  Assuming there is only one Objectid in the ObjectidCollection as we told the BlockTable variable to hold "C".
Here is my code so you can see what I am trying to accomplish...
Using acTransTB As Transaction = acDocTB.TransactionManager.StartTransaction
            Try
                Dim acBT As BlockTable = acCurDBTB.BlockTableId.GetObject(OpenMode.ForRead)
                Dim acBTR As BlockTableRecord = acBT("ECDT_JobName").GetObject(OpenMode.ForRead)
                Dim acObjIds As ObjectIdCollection = acBTR.GetBlockReferenceIds(True, True)
                For Each acObjId As ObjectId In acObjIds
                    Dim acBref As BlockReference = acObjId.GetObject(OpenMode.ForWrite)
                    Dim myAttValsTB As New Dictionary(Of String, String)
                    If acBref.Name = "ECDT_JobName" Then
                        myAttValsTB.Add("JOB_NAME", strGenJobName.ToUpper)
                    End If
                    If acBref.Name = "ECDT_JobNo" Then
                        myAttValsTB.Add("JOB_NUMBER", strGenJobNumber.ToUpper)
                    End If
                    Dim myAttCollection As AttributeCollection = acBref.AttributeCollection
                    For Each myAttRefID As ObjectId In myAttCollection
                        Dim myAttRef As AttributeReference = myAttRefID.GetObject(OpenMode.ForWrite)
                        If myAttValsTB.ContainsKey(myAttRef.Tag) Then
                            myAttRef.TextString = myAttValsTB(myAttRef.Tag)
                        End If
                    Next
                Next
                acTransTB.Commit()
            Catch
            Finally
            End Try
        End Using
Message 5 of 11
How many objectId's in ObjectidCollection depends on how many times that block is inserted 0 to whatever
If you want different blocks - a simple basic way is to itterate through the blocktable and check if the BlocktableRecord.IsLayout is false
This does nothing but shows idea
        <CommandMethod("AllBlocksAndReferences")> _
        Public Sub AllBlocksAndReferences()
                For Each objId As ObjectId In bt
                    Dim btr As BlockTableRecord = objId.GetObject(OpenMode.ForRead)
                    If Not btr.IsLayout Then
                        Dim objIdColl As ObjectIdCollection = btr.GetBlockReferenceIds(TrueTrue)
                    End If
                Next
            End Using
        End Sub
Here is something simple I just posted for someone about Sending Block Name and Count to Excel using COM that uses same idea
  [CommandMethod("ExcelAndCom")]
        public void ExcelAndCom()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            Microsoft.Office.Interop.Excel.Application excel = new Microsoft.Office.Interop.Excel.Application();
            Microsoft.Office.Interop.Excel.Workbook wb = excel.Workbooks.Add("");
            Microsoft.Office.Interop.Excel.Worksheet ws = excel.ActiveSheet as Microsoft.Office.Interop.Excel.Worksheet;
            ws.Range["A1"].Value = "Block Name";
            ws.Range["B1"].Value = "Block Count";
            int row = 1;
            using (Transaction trx = db.TransactionManager.StartTransaction())
                BlockTable bt = db.BlockTableId.GetObject(OpenMode.ForRead) as BlockTable;
                foreach (ObjectId objId in bt)
                    BlockTableRecord btr = objId.GetObject(OpenMode.ForRead) as BlockTableRecord;
                    if (!(btr.IsLayout))
                        row++;
                        int coloum = 1;
                        ws.Cells[row, coloum] = btr.Name;
                        ObjectIdCollection objIdColl = btr.GetBlockReferenceIds(true, true);
                        coloum++;
                        ws.Cells[row, coloum] = objIdColl.Count.ToString();
            excel.Visible = true;
Message 6 of 11
Rob.O
Strange... for some reason when I run the code with two different block references in the drawing, it only picks up the first one it finds. So basically the objIdColl variable only has a count of 1.  If I make one copy of the block that it finds and run the code again the count is 2, but its only counting the duplicate blocks and not the separate block reference.  Am I doing something wrong?
Message 7 of 11
Are the block dynamic, older demand loaded etc.....
Load up a dwg with some of the blocks you are refering to
Message 8 of 11
Rob.O
I created a new drawing and added the two blocks.  Both are simple attribute blocks.  If I run the code with both blocks in the drawing, neither of the attribute values are updated.  But if I delete one of the blocks and purge the drawing and then run the code, the attribute value of the remaining block updates as expected.
Drawing is attached.
Code is here:
Public Class UpdateAttribute
                    objIdColl = btr.GetBlockReferenceIds(True, True)
                End If
            Next
            For Each objId In objIdColl
                Dim acBref As BlockReference = objId.GetObject(OpenMode.ForWrite)
                MsgBox(acBref.Name)
                    myAttValsTB.Add("JOB_NAME", "this is a test-Job Number")
                End If
                    myAttValsTB.Add("JOB_NAME", "this is a test-Job Name")
                End If
                    End If
                Next
            Next
            trx.Commit()
        End Using
    End Sub
End Class
Message 9 of 11
You are iterating through the block table and setting objIdColl to each Blocks  blockreferences
then after the last one is when your code begins to modify
Just made a qick change
                For Each btrObjId As ObjectId In bt
                    Dim btr As BlockTableRecord = btrObjId.GetObject(OpenMode.ForRead)
                    If btr.IsLayout Then
                        Continue For
                    End If
                        MsgBox(acBref.Name)
                        Dim myAttValsTB As New Dictionary(Of StringString)
                            myAttValsTB.Add("JOB_NUMBER""this is a test-Job Number")
                        End If
                            myAttValsTB.Add("JOB_NAME""this is a test-Job Name")
                        End If
                            End If
                        Next
                    Next
                Next
                trx.Commit()
            End Using
        End Sub
Message 10 of 11
Also change
"JOB_NAME"
to
"JOB_NUMBER"
in the first one for both to change
Message 11 of 11
Rob.O
PERFECT!!!
Thanks so much for all of your help on this!  I will be sure to look you up when I need more assistance!!! Smiley Happy
