best way to process data when iterate each object in modelspace
wesbird
wesbird
hi,
I just built a app. now I like to make some re-factory. I found I iterate all objects of whole modelspace in 5 places. it will take lot of time for big drawing. I like to change to scan modelspace once.
also make the 5 tasks configurable. depend on the config file, I can run 1 task, or 5 tasks.
how should I design the code?
Here is code I use, which should from Scott McFarlane and Tony T.
public static void ForEach<T>(this Database database, Action<T> action)
            where T : Entity
            database.UsingModelSpace((tr, modelSpace) => modelSpace.ForEach(tr, action));
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
norman.yuan
Assume the argument Action<T> is one of the 5 tasks. Obviously, you need to call 5 times of the Database.ForEach<T>() extension method to get the 5 tasks done with each call needs to loop through the database's ModelSpace. I would not think simply looping through itself takes much time. rather it is what you do in the Action<T> really matters.
If you really want to only loop through the modelspace once, the you can change the database extension method signature, by passing in a collection of Action<T>,  like this:
public static void ForEach<T>(this Database database, IEnumerable<Action<T>> actions)
Obviously you also need to modify the extension method
BlockTableRecord.ForEach(this BlockTableRecord space, Transaction tran, IEnumberable<Action<T>> actions)
Norman Yuan
Drive CAD With Code
wesbird
thank you, @norman.yuan:
that's what I thought at beginning. but it only work with simple task. for some tasks are really complicate,
a. before ForEach, I need initialize
b. during ForEach, I need filter and action, and filter and action are different between task
c. after ForEach, I need do different kind of calculation according to the data I collection in the ForEach
what's the best way to solve this?
Thank you a million
