- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone!
I've got an exiting problem while trying to batch pdf export.
My task is quite simple: first, look through the drawing (all the lists and model space) and find all dynamic blocks with effective name "SheetGOST", case it's a drawing frame; second, export areas surrounded by those frames to pdf page by page. I've decided that plotting areas via "DWG To PDF.pc3" would be the easiest way.
Practically all the steps made: I get collection of blocks, I know howto print one of them to pdf, and it,s working correctly. The problem is, when I try to plot all the areas in cycle, in output pdf I get num of pages according to num of lists, and only the last area from the list. Test document contains 24 blocks on 3 lists, I get 3 page pdf with 7th, 22th and 24th frame printed..
I ran out of the ideas where I went wrong =(
The code is:
[CommandMethod("PlotToPdf")] static public void MultiSheetPlot() { Document doc = Application.DocumentManager.MdiActiveDocument; Editor ed = doc.Editor; Database db = doc.Database; Transaction tr = db.TransactionManager.StartTransaction(); using (tr) { List<GostBlk> BlocksToPlot = new List<GostBlk>(); List<Layout> LayList = new List<Layout>(); GetGostStampCollection(db, ed, tr, ref BlocksToPlot, ref LayList); ed.WriteMessage("\nThe number of GOST stamps found: " + BlocksToPlot.Count + "\n\n"); if (BlocksToPlot.Count < 1) return; if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting) { PlotEngine pe = PlotFactory.CreatePublishEngine(); using (pe) { PlotProgressDialog ppd = new PlotProgressDialog(false, BlocksToPlot.Count, true); using (ppd) { int numSheet = 1; ppd.set_PlotMsgString(PlotMessageIndex.DialogTitle, "Custom Plot Progress"); ppd.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage, "Cancel Job"); ppd.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage, "Cancel Sheet"); ppd.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption, "Sheet Set Progress"); ppd.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption, "Sheet Progress"); ppd.LowerPlotProgressRange = 0; ppd.UpperPlotProgressRange = 100; ppd.PlotProgressPos = 0; ppd.OnBeginPlot(); ppd.IsVisible = true; pe.BeginPlot(ppd, null); foreach (GostBlk gblk in BlocksToPlot) { ppd.StatusMsgString = "Plotting block " + numSheet.ToString() + " of " + BlocksToPlot.Count.ToString(); ppd.OnBeginSheet(); ppd.LowerSheetProgressRange = 0; ppd.UpperSheetProgressRange = 100; ppd.SheetProgressPos = 0; PlotInfoValidator piv = new PlotInfoValidator(); piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled; PlotPageInfo ppi = new PlotPageInfo(); PlotInfo pi = new PlotInfo(); BlockReference blk = gblk.BlockRef; Layout lo = gblk.LayoutRef; Extents3d ext = (Extents3d)blk.Bounds; Point3d first = ext.MaxPoint; Point3d second = ext.MinPoint; ResultBuffer rbFrom = new ResultBuffer(new TypedValue(5003, 1)), rbTo = new ResultBuffer(new TypedValue(5003, 2)); double[] firres = new double[] { 0, 0, 0 }; double[] secres = new double[] { 0, 0, 0 }; acedTrans(first.ToArray(), rbFrom.UnmanagedObject, rbTo.UnmanagedObject, 0, firres); acedTrans(second.ToArray(), rbFrom.UnmanagedObject, rbTo.UnmanagedObject, 0, secres); Extents2d window = new Extents2d(firres[0], firres[1], secres[0], secres[1]); // We need a PlotSettings object based on the layout settings which we then customize PlotSettings ps = new PlotSettings(lo.ModelType); LayoutManager.Current.CurrentLayout = lo.LayoutName; pi.Layout = lo.Id; ps.CopyFrom(lo); // The PlotSettingsValidator helps create a valid PlotSettings object PlotSettingsValidator psv = PlotSettingsValidator.Current; psv.SetPlotWindowArea(ps, window); psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Window); psv.SetUseStandardScale(ps, true); psv.SetStdScaleType(ps, StdScaleType.ScaleToFit); psv.SetPlotCentered(ps, true); //StdScaleType.StdScale1To1 psv.SetPlotConfigurationName(ps, "DWG To PDF.pc3", "ISO_A3_(297.00_x_420.00_MM)"); pi.OverrideSettings = ps; piv.Validate(pi); if (numSheet == 1) { pe.BeginDocument(pi, doc.Name, null, 1, true, "c:\\multiblock"); } pe.BeginPage(ppi, pi, (numSheet == BlocksToPlot.Count), null); pe.BeginGenerateGraphics(null); ppd.SheetProgressPos = 50; pe.EndGenerateGraphics(null); // Finish the sheet pe.EndPage(null); ppd.SheetProgressPos = 100; ppd.PlotProgressPos += Convert.ToInt32(100 / BlocksToPlot.Count); ppd.OnEndSheet(); numSheet++; } // Finish the document pe.EndDocument(null); // And finish the plot ppd.PlotProgressPos = 100; ppd.OnEndPlot(); pe.EndPlot(null); } } } else { ed.WriteMessage("\nAnother plot is in progress."); } } }
