Automatic selection
Automatic selection
Automatic selection
Here is a code where the user makes the selection of objects in the drawing, having a filter with two criteria:
Type and block with Dimension layer.
My question is:
How can I check is the same, without requiring the user to select objects in the drawing? (An automatic selection)
Robson (Brazil)
Choirs colleagues
Sorry, had posted the code before.
[CommandMethod("COTAS")]
public void cotas()
     Document documento = Application.DocumentManager.MdiActiveDocument;
     Database bancoDados = documento.Database;
     Editor editor = documento.Editor;
     TypedValue[] criterio = new TypedValue[2];
     criterio.SetValue(new TypedValue((int)DxfCode.Start, "INSERT"), 0);
     criterio.SetValue(new TypedValue((int)DxfCode.LayerName, "Dimension"), 1);
     SelectionFilter selecao = new SelectionFilter(criterio);
     PromptSelectionResult selPrompt;
     selPrompt = editor.GetSelection(selecao);
     if (selPrompt.Status == PromptStatus.OK)
               SelectionSet ssSet = selPrompt.Value;
Robson (Brazil)
Instead of GetSelection(), use SelectAll().
caddzone,
Thanks for the help, worked perfectly.
Hug.
Robson (Brazil)
