Automate the save as proccess
Hi all
I am doing my first AutoCad project and have a couple of questions.
First a discription of what I am trying to acomplish...
I am extracting data from a drawing file, to do this I am converting the drawing to xml and then have a xml reader that extracts the data.
I am at the point where I run netload and extractall this then creates the xml but pops up a "Save as dialog/file browser" where I then have the option to give the xml file a name and to choose the directory.
I want to find a way to hard code the directory where the file saves and also give it a name, so no user input. It takes the name of the drawing file and name the xml the same (except of course for the file extention) then save it to a default directory.
Is there a way to access the API and accomplish this?
Also is there a way to close autocad automaticallly after the XML has been created?
I am very new to this so go easy on me please
Thanks in advance
Johan
michael_robertson
Can you show the code for how you are trying to save the xml file?
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
I made a huge mistake in my code and now solved this problem thank you very much though
