Automate AutoCAD from a website using .NET is it possible?
Dear All,
I am wondering is it possible to do such thing? if so is there any links for me to study?
Currently I got this project to build a web application and from the web automate the Autocad drawing.
Thanks in advance
Hasegawa
arcticad
There is http://freewheel.autodesk.com/ which is just for viewing and printing.
It may be possible using the http://www.opendesign.com/
(defun botsbuildbots() (botsbuildbots))
I tried once to no avail. I forget what the exact complication was. It could probably be done, but rather than waste time beating the problem to death, I created a web service. Speaking broadly, I used a web application to get information about what actions needed to be performed. I then created a Windows Forms app that controlled AutoCAD through COM (though not the best way), and queried the web service from the Windows app to retrieve the info.
This might seem like a long way around the bush, but IMO it makes more sense because you don't need to run AutoCAD on your web server.
arcticad
Autocad does not license Autocad to run on a server.
That being said it could be done,
By using another API to modify a drawing directly will allow you to have more control and not be limited by AutoCAD being busy.
Thanks all for the reply.
arcticad: are there any site where I can get an example?
thanks again
