AutoLISP messagebox to C# text box
I am using AutoLISP for measuring total length of a line and it shows autocad message box as shown in picture.
But I want to display the length into winform of C#.
is it possible to do that?
Any kind of help is badly needed.
regards
Banna
_gile
Mixing LISP and .NET often brings more issues than easy solutions.
Anyway, you can show a winform from within LispFunction attributed method.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
dgorsman
Doesn't even need to be a winform - a MessageBox would do, as it's very similar to the LISP (alert ...) function.
Can you please share the code?
_gile
To use the standard MessageBox, you can simply build a simple LispFunction method:
        [LispFunction("messagebox")]
        public bool MessagegBox(ResultBuffer resbuf)
            if (resbuf != null)
                var arg = resbuf.AsArray()[0];
                if (arg.TypeCode == (int)LispDataType.Text)
                    MessageBox.Show(arg.Value.ToString());
                    return true;
            return false;
Usage:
(messagebox "Total length of selected objects is 1523.401")
If you want to use a "custom" message box, you can use the same way.
A trivial example of custom message box:
    public class MsgBox : Form
        public MsgBox(string msg)
            Size = new System.Drawing.Size(250, 110);
            StartPosition = FormStartPosition.CenterParent;
            Text = "Message from LISP";
            FormBorderStyle = FormBorderStyle.FixedDialog;
            AutoSize = true;
            MinimizeBox = false;
            MaximizeBox = false;
            Controls.Add(new Label()
                AutoSize = true,
                Location = new System.Drawing.Point(13, 13),
                Text = msg
            Controls.Add(new Button
                DialogResult = DialogResult.OK,
                Location = new System.Drawing.Point(80, 37),
                Text = "OK"
The LISP function:
        [LispFunction("msgbox")]
        public bool MsgBox(ResultBuffer resbuf)
            if (resbuf != null)
                    using (var dlg = new MsgBox(arg.Value.ToString()))
                        Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(dlg);
                    return true;
            return false;
Usage:
(msgbox "Total length of selected objects is 1523.401")
Gilles Chanteau
GileCAD
GitHub
