AutoCAD UI Winforms Design Guidelines
Dale.Bartlett
Dale.Bartlett
Hi All, I can't seem to locate a published guideline specifying AutoCAD Winform design specifications. For example: button sizes, colours, form sizes, control clearances, etc. Any links? Thanks again. Dale
______________
Yes, I'm Satoshi.
none that i recall, if any, but found this:
http://forums.augi.com/showthread.php?159459-CP304-4-AutoCAD-NET-Developing-a-User-Interface-Using-W...
might help you, it is by: Instructor: Gopinath Taget
Dale.Bartlett
Hi, Thank you very much for the link. I came on this while searching, but the old AU content seems to be ditched. The Autodesk AU site only goes back to 2012 so I couldn't retreive the complete set. This will be helpful, but surely Autodesk has strict guidelines for their development team somewhere. Regards, Dale
______________
Yes, I'm Satoshi.
yes, i did not checked if this class was still avail (actually never tried that au place before), appears that from some time on, these handouts are on augi:
http://autodesk.blogs.com/between_the_lines/2005/02/au_handouts_fro.html
hth.-
dgorsman
Almost certainly.  However I doubt they are publicly available, and there is no need for you to follow them.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Dale.Bartlett
I did see that AUGI were to host the AU content, then couldn't track it down, then found a post to the effect that it never happened. However, your link solved the confusion. All pre 2012 AU courses are here:
http://forums.augi.com/forumdisplay.php?1271-Autodesk
Why Autodesk is not hosting this valuable content is a mystery.
I am still looking for an official UI document similar to Autodesk Icon Guidelines 2008. I have searched the SDK but of course could have missed something (it happens..). Dale
______________
Yes, I'm Satoshi.
hgasty1001
HI,
This is from Microsoft: UI Guidelines
This is from Apple: UI Design Basics
Gaston Nunez
