Autocad .net check sub-entity visibility
hugh.powell
hugh.powell
We are working on some .Net c# scripts for drawing validation & checking, some of these scripts end up intentionally selecting sub-blocks of various blocks.
The parent blocks contain visibility states that are use to control the visibility of these subblocks.
From my script is there any way I can determine if the subblocks are visible or not.
hugh.powell
As per standard, I looked for an hour or two couldn't find anything and then figured it out shortly after asking.
For anyone else with this problem, for the parent block you have to check if AnonymousBlockTableRecord is not null, if its not null use it instead of the standard BlockTableRecord when looping over sub-entities, this allows you to then the check the .Visible property on the sub-entities.
