AutoCAD .NET API: Can I add Automatic property definition to propertysetDefinition?
ebi1007
ebi1007
I would like to add automatic property definitions. When I tried the code I found on the net, there is no error, but the property set definition is not created. If you have any other valid codes, please let me know.
var autoPropDef = new PropertyDefinition();
autoPropDef.SetToStandard(database);
autoPropDef.SubSetDatabaseDefaults(database);
autoPropDef.Name = "オブジェクトID";
autoPropDef.IsVisible = true;
autoPropDef.IsReadOnly = true;
autoPropDef.FormatId = dictionaryPropertyDataFormat.GetAt("Standard");
autoPropDef.SetAutomaticData(SolidClassName, "オブジェクトID");
propertySetDefinition.Definitions.Add(autoPropDef);
Gepaha
You didn't show the code where the PropertySetDefinition was added to the database.
Also, did you correctly assign the class name to SolidClassName?
Take a look at the links below, it shows how to create a PropertySetDefinition and add it to the database.
https://adndevblog.typepad.com/aec/2012/09/defining-a-property-set-definition-in-net-.html
https://forums.autodesk.com/t5/net/create-properties-in-custom-category/td-p/9385059
ebi1007
Thank you for replay. I've already took a look  that site.
This is my code below. What is wrong?
var database = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database;
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
var SolidClassName = RXObject.GetClass(typeof(Solid3d)).Name;
var TINClassName = RXObject.GetClass(typeof(TinSurface)).Name;
var AlignmentClassName = RXObject.GetClass(typeof(Alignment)).Name;
var dictionaryPropertyDataFormat = new DictionaryPropertyDataFormat(database);
using (Transaction transaction1 = database.TransactionManager.StartTransaction())var propertySetDefinition = new PropertySetDefinition();
 propertySetDefinition.SetToStandard(database);
 propertySetDefinition.SubSetDatabaseDefaults(database);
 propertySetDefinition.AlternateName = propertySetName;
 propertySetDefinition.IsLocked = false;
 propertySetDefinition.IsVisible = true;
 propertySetDefinition.IsWriteable = true;
 //適用タブ
 var filters = new StringCollection();
 filters.Add(SolidClassName);
 filters.Add(TINClassName);
 filters.Add(AlignmentClassName);
 propertySetDefinition.SetAppliesToFilter(filters, false);
 //定義タブ
 autoPropDef.Automatic = true;
 autoPropDef.IsReadOnly = false;
 autoPropDef.SetAutomaticData(SolidClassName, "ObjectID");
 //autoPropDef.DataType = Autodesk.Aec.PropertyData.DataType.AutoIncrement;
 propertySetDefinition.SetDisplayOrder(autoPropDef, 1);
Gepaha
string propertySetName = "MyTest";
   //適用タブ
   //定義タブ
   var dictionaryPropertySetDefinitions = new DictionaryPropertySetDefinitions(database);
   if (dictionaryPropertySetDefinitions.Has(propertySetName, transaction1))
      return;
   dictionaryPropertySetDefinitions.AddNewRecord(propertySetName, propertySetDefinition);
   transaction1.AddNewlyCreatedDBObject(propertySetDefinition, true);
   transaction1.Commit();
ebi1007
Thank you for your help.
However, I found that the problem was somewhere else.
