Autocad Get all elements
Hi guys,
How i can browse all objects into an autocad database ???
Hallex
There are many ways to get all objects from db
Here is what you can to use, expand functionality
to your suit:
        [CommandMethod("gall")]
        public void GetAllFromDb()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            ObjectIdCollection ids = new ObjectIdCollection();
            using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                for (long i = 0; i < db.Handseed.Value; i++)
                    ObjectId id = ObjectId.Null;
                    db.TryGetObjectId(new Handle(i), out id);
                    if (id != ObjectId.Null && !id.IsErased) ids.Add(id);
                foreach (ObjectId id in ids)
                    DBObject obj = tr.GetObject(id, OpenMode.ForRead, false) as DBObject;
                    ed.WriteMessage("\nType of:\t{0}\t{1}\n", obj.GetRXClass().DxfName,id);
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
thanks a lot, let me try it
This code is working fine , no problem on that, but what i'm looking for is, how i can get all the objects user does, because i need to export all objects (lines, circles...etc) and in the xml, I will export all properties of those objects (air, length...etc)
thanks a lot of help
Hallex
In this case better yet to use datextraction methods,
search for this on google or on "through the interface" web page:
http://through-the-interface.typepad.com/
there is an example in there
~'J'~
Hallex
Here is my old code I've grabbed from Kean Walmsley
See if this helps
        #region "System"
using System;
using System.IO;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Runtime.InteropServices;
using System.Diagnostics;
using System.Data;
using System.Timers;
using System.Windows.Forms;
#endregion
#region "AutoCAD Imports"
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.DataExtraction;
#endregion
       //' based on Kean Walmsley's example from there:
        //' http://through-the-interface.typepad.com/through_the_interface/2008/04/extracting-data.html
        [CommandMethod("extdata")]
        public void ExtractData()
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            double starttime = 0;
            double endtime = 0;
            System.Windows.Forms.OpenFileDialog dialog = new System.Windows.Forms.OpenFileDialog();
            dialog.CheckPathExists = true;
            dialog.DefaultExt = "dwg";
            dialog.DereferenceLinks = true;
            dialog.Multiselect = false;
            dialog.Filter = "Drawing (*.dwg)|*.dwg|All files (*.*)|*.*";
            dialog.Title = "Select drawing";
           dialog.FilterIndex = 1;
            if (dialog.ShowDialog() != System.Windows.Forms.DialogResult.OK)
                return;
            string fname = dialog.FileName;
            System.Timers.Timer _timer = new System.Timers.Timer();
          _timer.Interval = 1000;
          _timer.Start();
          starttime = DateTime.Now.TimeOfDay.TotalMilliseconds;
            try
                // following datatable easy to write to the any data file (Excel, Access etc)
                System.Data.DataTable dataTable = extractLinesAndTexts(fname);
                 _timer.Stop();
                     endtime = DateTime.Now.TimeOfDay.TotalMilliseconds;
                //' write data to Lines.xml in the Debug folder
                dataTable.WriteXml("LinesAndTexts.xml");
                ed.WriteMessage("\nElapsed time: {0:f2} milliseconds" + "\n" + "Found {1} objects\n" , endtime - starttime, dataTable.Rows.Count);
            catch (System.Exception ex)
                MessageBox.Show(ex.ToString() + "\n" + ex.StackTrace);
            //' Display the  file
            Process.Start("LinesAndTexts.xml", null);
        public System.Data.DataTable extractLinesAndTexts(string fname)
            System.Data.DataTable dataTable = new System.Data.DataTable();
            System.Data.DataTable blkTable = new System.Data.DataTable();
            List<string> tags = new List<string>();
            if (!System.IO.File.Exists(fname))
                ed.WriteMessage("\nDrawing file does not exist.\n");
                return null;
            IDxExtractionSettings es = new DxExtractionSettings();
            IDxDrawingDataExtractor de = es.DrawingDataExtractor;
            de.Settings.ExtractFlags = ExtractFlags.None | ExtractFlags.ModelSpaceOnly;
            de.Settings.ExtractFlags = ExtractFlags.ExtractBlockOnly;
            //'Or ExtractFlags.ModelSpaceOnly
            IDxFileReference fr = new DxFileReference(Path.GetDirectoryName(fname), fname);
            de.Settings.DrawingList.AddFile(fr);
            // Scan the drawing for object types & their properties
            de.DiscoverTypesAndProperties(Path.GetDirectoryName(fname));
            List<IDxTypeDescriptor> types = de.DiscoveredTypesAndProperties;
            // Select all the types and properties for extraction
            // by adding them one-by-one to these two lists
            List<string> selTypes = new List<string>();
            List<string> selProps = new List<string>();
            foreach (IDxTypeDescriptor type in types)
                selTypes.Add(type.GlobalName);
                foreach (IDxPropertyDescriptor pr in type.Properties)
                    if (!selProps.Contains(pr.GlobalName))
                        selProps.Add(pr.GlobalName);
            de.Settings.SetSelectedTypesAndProperties(types, selTypes, selProps);
            // Now perform the extraction itself
            de.ExtractData(Path.GetDirectoryName(fname));
            // Get the results of the extraction
            dataTable = de.ExtractedData;
            if (dataTable.Rows.Count > 0)
                dataTable.TableName = "LinesAndTexts";
                DataRow[] selrows = dataTable.Select("AcDxObjectTypeGlobalName Like '%Line' Or AcDxObjectTypeGlobalName Like '%Text' Or AcDxObjectTypeGlobalName Like '%MText'");
                blkTable = dataTable.Clone();
                foreach (DataRow dr in selrows)
                    blkTable.ImportRow(dr);
                //' commented code lines is just for populating a form listBox control:
                //Dim columns As String() = New String() {"AcDxObjectTypeName"}
                //Dim dvw As DataView = blkTable.DefaultView
                //distinctTable = dvw.ToTable(False, columns)
                //Dim bnames As New List(Of String)()
                //For Each dr As System.Data.DataRow In distinctTable.Rows
                //    Dim bname As String = dr(0).ToString()
                //    If Not bnames.Contains(bname) Then
                //        bnames.Add(bname)
                //    End If
                //Next
                //Me.lst.DataSource = bnames'' <-- to fill ListBox only
                //lst.SelectedIndex = -1'' <-- set selected items to nothing
            return blkTable;
~'J'~
