Autocad event Handler goes into an infinite loop
inversiones_edgar_itriago
Hello, I'm writing a C # program that retrieves the CENTERVIEW of any existing floating viewport when it is activated by user (Double Click). I have added an Event Handler to currentViewportChanged, but the event handler goes into an infinite loop when any Viewport is activated, see code in the attached file. Thanks!
5thSth
depending on how "clean" your code you want to be,
I suggest either:
1) use messagefilter to look for mouse kliks, so your event to count only after mouse klik has been accepted.
2) use a timer and allow only one eventhandler to trigger per second
_gile
Hi
This works for me:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using System.ComponentModel;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace ViewportToWorldCoordinates
    public class Commands
        [CommandMethod("EV")]
        public void UIBindingsNotificationExample()
            INotifyPropertyChanged source = Application.UIBindings.CurrentViewport as INotifyPropertyChanged;
            source.PropertyChanged += currentViewportChanged;
        void currentViewportChanged(object sender, PropertyChangedEventArgs e)
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            // Check to see if the Model layout is active
            if (db.TileMode)
                // Model layout
            else
                var cvport = (short)AcAp.GetSystemVariable("CVPORT");
                if (cvport == 1)
                    // paper space
                else
                    using (var tr = db.TransactionManager.StartTransaction())
                        var vp = (Viewport)tr.GetObject(ed.ActiveViewportId, OpenMode.ForRead);
                        Matrix3d EyeToWorld =
                            Matrix3d.Rotation(-vp.TwistAngle, vp.ViewDirection, vp.ViewTarget) *
                            Matrix3d.Displacement(vp.ViewTarget - Point3d.Origin) *
                            Matrix3d.WorldToPlane(vp.ViewDirection);
                        var ptCenter = new Point3d(vp.ViewCenter.X, vp.ViewCenter.Y, 0).TransformBy(EyeToWorld);
                        ed.WriteMessage("\n*** Current Viewport= {0} ViewVenter=  {1},{2}\n", cvport, ptCenter.X, ptCenter.Y);
                        tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Ok, I check your code, the event ceased the infinite loop, but now executes 3 and 4 times consecutives, but at least improved je je je.
