Hi
This works for me:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using System.ComponentModel;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace ViewportToWorldCoordinates
public class Commands
[CommandMethod("EV")]
public void UIBindingsNotificationExample()
INotifyPropertyChanged source = Application.UIBindings.CurrentViewport as INotifyPropertyChanged;
source.PropertyChanged += currentViewportChanged;
void currentViewportChanged(object sender, PropertyChangedEventArgs e)
var doc = AcAp.DocumentManager.MdiActiveDocument;
var db = doc.Database;
var ed = doc.Editor;
// Check to see if the Model layout is active
if (db.TileMode)
// Model layout
else
var cvport = (short)AcAp.GetSystemVariable("CVPORT");
if (cvport == 1)
// paper space
else
using (var tr = db.TransactionManager.StartTransaction())
var vp = (Viewport)tr.GetObject(ed.ActiveViewportId, OpenMode.ForRead);
Matrix3d EyeToWorld =
Matrix3d.Rotation(-vp.TwistAngle, vp.ViewDirection, vp.ViewTarget) *
Matrix3d.Displacement(vp.ViewTarget - Point3d.Origin) *
Matrix3d.WorldToPlane(vp.ViewDirection);
var ptCenter = new Point3d(vp.ViewCenter.X, vp.ViewCenter.Y, 0).TransformBy(EyeToWorld);
ed.WriteMessage("\n*** Current Viewport= {0} ViewVenter= {1},{2}\n", cvport, ptCenter.X, ptCenter.Y);
tr.Commit();
