AutoCAD Dot Net Wizards for Visual Studio 2022.
BenoitLarocque000
BenoitLarocque000
Is there any templates Wizards for Autocad Dot Net 2022 for Visual Studio 2022?
I tried with a file named AutocadDetWizards.msi but it refused to install because it is associated to Visual Studio 2019.
Best Regards,
Benoit Larocque
_gile
As far as I know, there's none AutoCAD wizard for Visual Sutio 2022, but you can follow this tutorial to build your own template. This template was written for VS2017 but is easily transposable for later versions.
You can also clone this project template and edit it in order for the template to work on your work station.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
BenoitLarocque000
Thanks!
jmartensBGRRW
Is there a tutorial for VB.NET similar to this?
_gile
There was an old one, only in French: https://gilecad.azurewebsites.net/Resources/Template_VB.pdf
But if you are starting with .NET you should learn C# rather than VB because you will find more valuable examples and relevant help with C# than with VB. Moreover, Microsoft has announced that, unlike C#, it will not evolve VB anymore.
Gilles Chanteau
GileCAD
GitHub
jmartensBGRRW
Thank you for your help! Much appreciated.
