AutoCAD crashes after completing side Database Operation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The app I'm writing will eventually do some batch operation on multiple user-selected drawings
(Set DB.PSLTSCALE=1 for all Layouts in LayoutManager.Current), without opening those drawings.
For LayoutManager.Current to be available, WorkingDatabase is set to the selected database,
and being reset to the original database after the side-database operation completes.
All of this should work while the current Document is opened and waiting for the process to complete,
and return to regular user operation at the end.
But for some reason, after the DB.SaveAs is completed, the application crashes.
I ahve no clue whether the problem is in the file to be processed or in the code.
Following is a simplified code, in which the attached drawing's Database is Opened by the program for processing,
then being SavedAs, then the crash...
Any help will be kindly appreciated.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Windows
Public Class TestClass
'<CommandMethod("TestPS1M")> _ ' This has also been tested, no success...
<CommandMethod("TestPS1M", CommandFlags.Session)> _
Public Sub TestPS1M()
Dim curDB As Database = HostApplicationServices.WorkingDatabase
Dim myFilename As String = "c:\DatabaseToProcess.dwg" 'This is the attached drawing
Using myDB As New Database(False, True)
myDB.ReadDwgFile(myFilename,
FileOpenMode.OpenForReadAndWriteNoShare, True, "")
HostApplicationServices.WorkingDatabase = myDB
Dim curLM As LayoutManager = LayoutManager.Current
' Saving original active layout name
Dim curLayoutName As String = curLM.CurrentLayout
Using dictionaryTrans As Transaction = myDB.TransactionManager.StartTransaction
Dim myLayoutDict As DBDictionary =
dictionaryTrans.GetObject(myDB.LayoutDictionaryId, OpenMode.ForRead)
' Iterating Layouts setting PSLTSCALE=1
For Each myEntry As DBDictionaryEntry In myLayoutDict
Using layoutTrans As Transaction = myDB.TransactionManager.StartTransaction
curLM.CurrentLayout = myEntry.Key
myDB.Psltscale = 1
layoutTrans.Commit()
End Using
Next
' Resetting the original active layout
curLM.CurrentLayout = curLayoutName
dictionaryTrans.Commit()
End Using
HostApplicationServices.WorkingDatabase = curDB
myDB.SaveAs(myFilename, True, DwgVersion.Current, myDB.SecurityParameters)
End Using
MsgBox("Not crashed yet...")
End Sub ' program crashes here ****************
End Class
